Nintendo Switch thread
jayz_sg
Is this really official anker distributor? It seems way too cheap. :s22:
I Just purchased it, waiting for shipping to singapore :
https://www.amazon.com/RAVPower-20100mAh-Portable-Qualcomm-External/dp/B019IFIJW8
I think we need USB-C with PD to really charge the switch fast.
Any powerbank with QC3.0 or whatever doesnt work with the switch as it doesnt support it.
That is the exactly the same one I have been looking at. Seems like this is the best bet for now.
For those who bought xiaomi power bank gen 2 and can't charge the Switch when playing Zelda, are you using the USB cable from Xiaomi? Try using a different USB A to C cable and try again. I read in some forums some user changed their cable and it works fine.
It comes with only USB-A to Micro USB cable. I tried with 5 different types of USB-A to USB-C cables, all show the same volt/amp draw.
ATZW1980
Does anyone have any idea on the above? :D
Well i do use samsung note 4 charger to charge my switch in turn off mode it works :p
And using my Sony power bank if i put brightness to 75% it charges the switch.
But i just came back from a europe flight the switch basically was on a 25% brightness ..... so the sony powerbank was charging
Thank god for the switch -.- the guy keep snoring and leaning toward me with bad breath.....
Thanks Tiger Palm oil too -.-
If not for the switch i dun know what will happened LOL
Healin
Based on the 20v power rule, I'll hazard a guess that this is not Qualcomm QuickCharge but USB Power Delivery. The Switch can use the 12V power rule.
Sorry... I really nerd in this. Means can work ah? LOLX. The charger came with my Miix720 Lenovo tablet/laptop de. :o
ATZW1980
it will work just a matter of will it charge the switch when you are playing with airplane mode off and full brightness and volume.
Cos turn airplane mode on, with 75% brightness and using headset LOZ: BOTW drained the switch much slower.
But if you are talking about putting to sleep mode and charge surely no issue
guanguan
Don't know want to buy usb c to usb c cable not.
So many cable now :
1. Usb3.0 to USB C (Bought it initally to charge the switch but not so fast)
2. Usb3.0 to micro usb ( to charge powerbank)
3. Usb to apple charger (charge iphone duh)
Another usb c to usb c cable? :s22:
ATZW1980
So many cable now :
Well so far i'm using a $6 SGD 90 degree USBA to USBC to charge my switch while on a tablet stand while playing. Work with no issue.
Sometime is better to get a shorter cable it does charge faster if the source is from powerbank
and a mirco usb to lightning head. 1 less cable
ATZW1980
$6 stand from Causeway point, $6 cable from Challenger. and a Sony powerbank.
ATZW1980
My experience with Belkin was not so good.
Basically i brought a lighting cable during one of my work trip.
Left my cable in the plane -.-
And the belkin plastic just crack near the usb head due to the fact i was always carrying it ard and twisting my cable as i keep taking it in and out while playing pokemon go.
and the cable was useless less than a month.
But i dont see it as a problem for the switch.
But since that incident i always buy the flat cable or the fabric cable.
Kwein
Hi how much and where did u purchase the 90 degree cable?
TIA!
doki81
comparing anker vs aukey..i would prefer aukey more for now....anker used to be quite good...but recent batch quality seem like no good. bought the 6 ports charger and have issue. charging slow + will have power leakage :(
Aukey cable..
