Nintendo Switch thread
noobzpro
Just receive
omg u receive le....i still waiting next batch....how snug is the fit? im planning to use with joycon covers
mudxblood
Would you guys rather buy digital or physical copy? Thinking of whether to build up my game library digitally or physically.
BigMonkey
depends. first u need to ask urself a few questions.
do you need to sell off the games after you complete?
do you like to keep things?
what is your priority? cheap or convienent? u have money to invest in micro sd(msd) card? at least SGD 130 for 200GB msd
XxGaiaxX
Few points to consider.
Re-sell games? - Physical
Wanna have a awesome looking game collection? - Physical
Want convenience? - Digital
If you dont care about a physical collection, buy physical for games you think you will sell off (like RPG, since after finishing the story once, no point playing back type).
Then buy those games which contains multiplayer / you will you will slot back in on and off like mario kart digital, so you can swap around easily.
NeonX
No problem unless u pack the 2 slots inside with other stuff. Inside is super soft
In total about 100
LegoAmon
No warranty from recent lazada switch sale
i just received my switch ytd noon, but there isn't warranty card inside the box. I wrote in to Lazada CS to request them check with seller, and within 3 hours, Lazada replied me that i suppose to have warranty card. They will check with seller and update me.
Anybody has same issue as me?
I havent start playing with the switch yet, in case i may need to return the console =/
darkraider
All local Switch are pre-registered by Maxsoft. You will need to keep the receipt of ur purchase.
ElZedHaitch
check your box. The serial number at the bottom cut out right?
ElZedHaitch
Export set has the cut out too.
ohh. okay. well there is also a sticker that write the japanese distributor but has the AC adaptor that writes for use in Singapore. But i am not sure if that means its local set. I trust lazada that they wont lie about it.
Yxy
I also cannot find any warranty card or receipt lol (received it yesterday)
