htngwilliam
- Dec 31, 2004
Ashland's cordovan wallets with reverse interior are fully shell cordovan. What you see on the interior of the wallet are the reverse side of the shell.
Ashland use thin horsehide for their Moc interior wallets. So it is usually priced cheaper than their full shell cordovan.
I have a Johnny the Fox Whiskey Moc interior from an earlier Massdrop's drop. Would have picked a full shell if the option was made available then. Horsehide interior on my wallet has stretched a bit and edges tend to curl up with 6-months use.
Thank you very much. Decided to whack 1 set to try. Wasted color #8 is sold out. Can only go for black.
