Xiaomi Mi 5!
wildfaye29
8.2.2 update via ota this morn
specifically address playstore update issue
carboy00
Anyone updated? Any issues?
So far still ok for me. Play Store issue is solved but under Play Store settings, device certification is now "Uncertified" (SafetyNet test has been failing after this update). A quick look on MIUI Forum shows some are facing issues with GPS (unsolved since 8.2.1), laggy gaming, front camera video recording audio issues and battery drain but these could be isolated cases though.
789asd
Avoid at all costs then. Thanks for warning
xuan87
Just hoot myself an Mi 5.
Currently on Global ROM.
Should I flash to China ROM or Lineage?
Lineage FTW! I'm running my Mi5 on Lineage 14 and no regrets
Pros
1) Regular updates with latest monthly android security patches, easy to flash with just one touch from the settings menu
2) Totally lag free
3) I prefer the stock android UI to the MIUI, and Lineage is close to the former with additional features
Cons
1) I cannot use Androidpay (no biggie) and Singtel WIFI
yukita
im still on miui 8.1.2.0, local set and still no update....
whatsapp abit lag and slow response with swiftkey also lag abit... :(
swathe
Can anyone explain why the processor relatively fast, RAM also sufficient but yet will lag?
Cos you are not an ****.
Of cos no update.
Must understand the Global ROM is made for ****.
That's why you must change your region to India in order to be able to update.
