Nintendo Switch thread
Jaxtor
Finally it's done. Hori Tough Case + Hori Joycon Cover + Key Factory Screen Cover.
Nice, beside protecting the front and docking, can it be used as a stand? When in handheld mode I Guess u flip the cover to the back? Doesn't it block the exhaust fan?
Chys
Actually no protection when docked as cover over. The cover cannot used as a stand. Exhaust not blocked.
Kiddream
Pro controller at $108 after discount. Is it worth it? Considering to get one. To all Bros here who are using pro controller, does it offer a big advantage over Joycons?
Arsene_Wenger
Suspended
Waaa. My left joy con suddenly not detect by the console or even charging. Luckily i pressed the tiny button beside the joy con and plug it again to work. Not sure why..
TrueBeliever_jh
MK8D reviews are out.
but game only out next week Friday :(
considering my last Mario Kart is Mario Kart DS and I didn't play much of it. let's see how things have changed.
Kwein
i'll probably buy for street fighter
Kince86
IMO, if you're using it mainly as a console, then a pro-controller would be nice. it'd be good to have a spare controller around for friends anyways...
for myself, I haven't even set up the dock lol. I'm using it as a handheld almost exclusively and i actually quite like the joy-con grips. not to mention i got no friends so no need for spare controller at home :o:o
I m looking to hold on a new Nitendo switch. found some sell at S$490 on lazada for AU set.
Could pls help suggest with warranty for those sets?
sure no local warranty but will it come w international warranty?
Usually you would have to ship it to the distributor at Australia... thats if they would even accept a warranty claim that way.
Went Down maxsoft. Tested mine joycon and said mine is one of the better batch.
Try covering with one hand and de sync occurs said is normal. I thought suppose to work well even though covered with hand?
mine joy-cons was good behind the thick belly of mine and roughly 4m away so.... yay!
the joy-con is so small, you prolly would have to cover it with a hand to use it anyways.... think they're just trying to not have to replace it
Marukoban
You mean got no gamer friends?
Can't be don't have friends.
Actually the pro controller is also nice if want to play tabletop.
I never set up dock as well, but from time to time use the pro controller to play tabletop. It can also be used to play on pc.
Gametaku
I think even have gamer friends..most likely they will play online and not via local MP. Local MP is more for family members.
Kince86
tried tabletopping a couple of times. the included kick stand is atrocious. the angle is bad, and i kept being worried that if i press on the console too hard it might slam onto the table when the kickstand gives way... kinda want the hori playstand. but am too cheap to buy one hahahaha:s12::s12:
closer friends who might come to my hse are non-gamers
not so close gamer friends are mostly pure mobile gamers lol
very true. now-a-days less and less gatherings too since most of us just connect tru social media.
kuniyo_keiji
local set with warranty is $560 neon.
Why buy $490 export set?
to me now maybe export set $450 or less then worth it
cynic_
