[Official] iPhone 7 (Plus) Discussions
carebeargal
front cam not working
hi, anyone facing similar issue?
yesterday my front cam is not working (freezes after switch from rear camera which is still working), tried with snapchat app also black screen. on whatsapp, the camera shows black screen. tried rebooting and resetting all settings but still no difference...
DanialRohmat
Hello.
Have you dropped your phone recently? This happened to me after I dropped my phone when it was caseless.
Either way, contact Apple and ask them to do a diagnostic test.
coolninja02
Anyone had this issue before? Battery took a long time to charge from 70% onwards.. using original plug and cable
Within one hour, percentage drop from 73% to 57%.. normal usage like whatsapp and surf facebook (never watch any video)..
Should i go replace the battery?
xttxtt
screen cracked on my IP7+...............
should i go fix it @ q lab ?
Q LAB PROS : $250 , apple certified screen
CONS : waiting time is about 7 working days
outside shop : $250 , AAA+ screen
CONS : will break apple warranty
:s11::s11::s11:
definitely the first. not worth losing the warranty over this.
xttxtt
bring it in to apple and let them check?
endlssorrow
i try to install a game then ir prompt the password for a few times.
Thereafter, it restart and the loading icon appear. And it keeps loading and loading (when switch on phone that icon loading type)
how long will it load? and y it is like that?
Matrock5
It happened to my ip7, the i went to the apple A lab at PS to get the camera changed. it was a hardware issue.
sunht
Hi, can someone share nowadays where is the best place to purchase cheaper brand-new sealed iPhone 7 plus set other than apple store?
SaulSilver
Got mine from red white mobile, that time dropped to 1150 but don't know why now the price went up again
Andrew833
Battery or display problem, bring to apple to check.
