LG G5
MacSpicy Cheeze
Sent from LGE LG-H860 using GAGT
squidy
Anyone interested in a grey camera module? Letting go at 60 bucks. Brand new.
reno77
My g5 starting having the vertical 1/2 tearing 2 days back when playing mobile legends..even after switching the phone resolution to 1080 from adb..but if I minimise the app and open some other app then maximise the game, the 1/2 screen lag goes off
Edit: Problem seems to be fixed after I switched on "force gpu for 2d graphics" in the developer mode
Reedit: Problem reappeared...
Re-reedit: Took apart the phone, used a hairdryer to heat the cpu, then pushed it down to make it hopefully stick on to the thermal paste. Also put some aluminum foil above the cpu to make better contact with the metal shield cover. Played 2 games of mobile legends without tearing..hope problem is fixed.
garyteo
What is the diff between local and Koren set? And of local lg service center provide support to Korean set?
Kinezone
any news on OTA update for LGG5. mine is stuck on 7.0 and April 2017 security patch...
there have many android versions since 7.0; including 8.0
garyteo
Yes, i am having the same issue, will getting a new battery help ??
Any encountering phone shutting off shortly when battery depletes below 15%, it's not boot looping just shutting off due to low power on both my batteries. My friend is facing same issue.
Kinezone
LG G5 updates?????
LG: never again; I already moved away from Samsung also not updating their devices and there is not much options left now...
dilphinus
Just realised that the camera lens cracked! Any idea where I can get it replaced cheap?
yanyewkay
Anyone had issues with gps before? Gps test shows its not receiving any gps signal at all.
EDIT: I solved it by opening the phone and putting a small piece of namecard under the 3 pins. Followed instructions online.
g_t2006
anyone knows the approximate prices for repairing the sound button and on-off button? out of warranty set. 2 months out of warranty.
