Accepted uni offer by accident
Crayons&Qoo
Hi guys,
I was offered SIT Criminology and I accidentally clicked on the accept offer on the joint acceptance portal by accident last night. Is there any way to undo this so I have more time to think? I also have a NTU sociology offer so I'm in a dilemma.
I applied for NUS comp Sci as well but it's unrelated to my diploma field of study. I was thinking of appealing into NUS FASS.
Will I be able to try and appeal into other degrees, such as NUS? And is there any way I can contact the portal administrator to request for some sort of rectification?
hexaarslan
Pretty sure you can modify your choice to "Ntu - Sociology" or "Reject all offers" by clickig the Modify button. And you can do this as many time as you want. Only the latest modification before the portal closes on May 25 will be registered and I think all the matriculation stuff will only start after the portal closes. At least for NTU and NUS.
Crayons&Qoo
Thank you so much for the clarification! I tried logging in with the NTU admission number and it returned an error so I panicked for a while. Managed to change my choice to NTU sociology instead so i guess all is well, seems like changing the offer acceptance should be unlimited until deadline passes. :)
Apple962
Hi hi
:s11:
Once I log in to the portal using e.g. SIT's application number, let's say I want to modify my choice cause I got offered by another uni.
I still use SIT application number to log in?
Sorry i'm kinda lost lol
WhiteChocolatte
Would also like to know whether i can reject a previously accepted course for more time to think before accepting it again? Or will I have no way to reaccept if I press "reject all courses"?
Oxsianx
Hi hi
:s11:
Hi both,
Yes you can use one application number to log into the portal. All the courses offered to you will be shown.
You are free to play with the choices. Such as accepting offer from uni A this moment. Then choose reject all offers. Then accept offer from uni B before the stipulated cut off date.
Apple962
Hi both,
Omg thanks for the reply. :) Btw, there's no log out button in the portal right? (Seeing from some screenshots)
What if I don't want to select anything yet ><
Blazer433
Why did you reject all offers if you want more time to think through??....
Piggychicken
Can I ask you I had just accepted ntu but I try to re log in and confirm again the portal shown you previously had accepted ntu Cs, did you face same issue that time ??does it mean I already accepted ntu right ? Coz I still can see the system below got show other Uni offered included NTU cs which I already accepted . Must I re submit or not ? Thank you
