Nintendo Switch thread
Kince86
Those looking for an affordable case with good protection can consider the Orzly case.
I actually find it too big for daily use since i do carry a pretty large messenger bag whenever i go out. Can see it being pretty nice if going out without an actual bag tho.
Lazada can't deliver on launch day right.
Wanna play this weekend.
safest launch day purchase would be via digital i believe. otherwise, self-collect. too many things can go wrong with deliveries to guarantee that you can receive it for the weekend
W3isheng
Which eShop will be the cheapest to buy puyo puyo tetris? Anyway what time does they update the eShop?
Marukoban
Canada is probably very slightly cheaper than US.
USD29.99 vs CAD39.99+5% tax will only differ by around 50 cents SGD.
I'm actually not very sure whether we can now buy from US eshop since last time overseas credit card was banned there.
Mexico or Australia might be cheaper, but I think those countries tend to have more expensive price.
No need to try European countries eshop because their price is 10 euro higher.
I think they probably will update the shop around noon US time, which is between 12-3am.
Kince86
Install eshop game on micro sd game is auto one or can choose?
you can't choose where to install games. if you have a sd card installed game installation will default to it.
if you really want to install to internal storage i guess you can take out the sd card when downloading the game
its kinda troublesome since u need to restart the switch whenever you remove/insert a sd card
StanII
yes you're right, that's why i nv pull the trigger on lazada, still deciding between digital copy or physical for MK8 as I believe i won't sell this game, whether it'll be a hassle to keep switching carts.
so far all my games are physical except snipperclips which was an eshop exclusive
Geopold
Kiddream
I used US Alaska with postal code 99501. No tax.
For those who bought it digitally? May I ask which eshop you are using? I noticed that my canadian acct no longer accepts my postal code. So I used a US acct and entered a fake US postalcode with my local CC info.
halocast
Looks like can dropped dragon quest heroes 2.
The multiplayer portion seems bad..
Wanted to get for coop.
doomgaze86
My main account is Canada. I faced the same issue as you earlier last month so I started using a Canadian postal code and it has worked fine so far. I chose Alberta as my state and T1X1E1 as my postal code.
