Xiaomi Redmi 4
ZrE0_Cha0s
New update again, any one tried.....?
this time rd whats the verison file name? last 2 update is the same name but the 2nd one is so call "stable"
edit: seems like its a beta update, as i have tried to update through OTA (no new update), tried looking at their download, (also dun have)
fwl18
Version number is 8.2.4.0MBEMIDL, yea realised its a nightly, not sure why I got a prompt to download!
ZrE0_Cha0s
well that means u are 1 of the few lucky user to get to test this new update.
but still up to u to update and test to tell the fourm abt the issues and the improve it has does.
ZrE0_Cha0s
ok now it has become stable version (got notification on the update) but definitely wont do it now. since all their rom eventually got taken off 2~3 days later.
anyway will go check on miui forum for more info on how this update works and its it really worth going for it.
ZrE0_Cha0s
anyone on m1 prepaid card with xiaomi phone esp MIUI 8 OS. do u have any issues connecting to data now?
as i have tested my network (able to call and sms) but data cant work. reset the apn, restart the phone and it still cant work. (btw my data was down when im at CBD area in ard 10am plus near to 11am.)
porfors
Your 2nd SIM can only support 3G..
Ensure its connected to 3G only..
Again i am running lineage everything works however, i have to manually selected 3G only for my 2nd SIM, default 2nd SIM selected to 4G.
ZrE0_Cha0s
well i only have that 1 m1 prepaid card and another slots for my memory card, have tried moving the sim card to 2nd sim, but still the same thing as well.
though i have to say that other devices are working fine, used another sim card of different provider and it works well. lastly i think im going reset to try and see.
Ender
Just bought a Redmi 4 Prime during the Lazada GSS sales for my son. After Wogi 20%, final price is $164.9 .. Hope this phone is not outdated yet, and Xiaomi still supporting it with firmware update.
MorningBun
Hi my I ask which phone are you using/referring to?
ZrE0_Cha0s
just received a new software update for prime, anyone did updated to 8.5.3?
ZrE0_Cha0s
I intend to get the local Redmi 4X with the local promotion at $199/-. Any word of advice / caution ?
ern...like what kind of advices and caution? :s11:
if u buying for mi store, u definitely have nothing to worry, any issues just visti their local warranty store to fix up your phone ;)
iammole
I updated and it screw up my credit card's online 2FA entry.
Used MiFlash to flash back to 8.2.4.
ZrE0_Cha0s
I updated and it screw up my online 2FA entry. always prompt wrong OTP.
wonder if can roll back to the older firmware.
I think u can do that, but I'm not sure how since I have not tried to rollback b4. But have seen such a thread on miui forun on redmi 4.
csc12345678
I think I've mixed up Redmi Note 4X and Redmi 4X.
I need to get a case and screen protector for my Redmi 4X. Do I have the concern of the China/Singapore version case/SP incompatibility ?
I'm confused already. I try to trace the forum but there are a number of entries and I'm not sure. Thanks for your help. Thank you very much.
csc12345678
Currently on MIUI 8.2.9.0.
Got update pending 8.5.2.0. Read there is some battery drain problem. Anyone updated ? Any issues ?
Thanks.
ZrE0_Cha0s
Thanks.
Even for me on redmi 4 prime also seen the MiUI forum about the battery issues but not all user reported.
But I have of yet done the update yet. But will probably do it to stop their annoying msg.
csc12345678
Thanks. I find it takes a little effort to push the 3.5 audio plug into the phone. It's not like my previous phone. Is it the same for you ?
ZrE0_Cha0s
For mine no issues. But maybe it's trying it make it'd more grippy? So that it won't be that easy to pull out.
