suntanoi1983
- Apr 2, 2010
ProAddon is great if you have Tomato/DDWRT/MerlinWRT and intend to use VPN on a router level. Their optimized RouterPro VPN protocol is much faster than standard OpenVPN.
I have flashed my archer C7 this morning with the DD-WRT firmware.
1) If u intend to keep up with the 1Gbps/2Gbps/10Gbps dl/ul speed, dont flash your router. It will be really lucky for u to hit 300mbps after the DD-WRT is installed. Again, our ISPs never let us get close to hitting 100 megabytes/s on 1 Gbps fibre line. Do the calculation urself. In term of security, the difference is there but minor.
2) say u can hit 30 mb/s - 40 mb/s on the router pro VPN, that's only like maxing a 300 mbps line. As compared to ISP's 60 mb/s - 80 mb /s dl speed. openVPN is good enough on the OS platform not router-level.
