the ONEPLUS 3
pspnewcomer
Hi, is there any screen protector that can use together with Spigen Rugged Armor case. This case always will push up tempered glass and normal screen protector. I like this case very much.
highdiver_2000
Mclairs83
Just want to prevent the screen from scratches. :). Thanks btw.
Sure there is a bunch of TGSP out there. But all of them give either rainbow effect, dotted matrix which make ur screen fugly.
If u want can try those wet application. But that one is super ex and u need alot of patient and skill to do it.
gong318
can try using orzly v2 if you don't mind the slight rainbow effect and slight weak touch sensitivity
gong318
Hi sorry if this question has been repeated again
Recently I've been testing out the camera and what I noticed that pre-processing/taking the photo, the image quality is very sharp, however after I click the button to take picture and after processing, the picture becomes not sharp anymore. Anyone knows the cause or solution to this?
initialtbk
I've experienced this too. No solution though that I know of. Up for others input.
Sent from OnePlus 3T using GAGT
Mclairs83
Are you using OOS or any other custom rom?
pspnewcomer
i tried before. But Spigen Rugged Armor case keep lifting side of the protector.
Mclairs83
as long as u guys using 3rd party app like instagram/whatsapp cam to take photo, it will not be processed by the OOS camera blobs.
batboyz
Yup, this is correct. In addition, OnePlus never released their camera blobs to public, so if you want the best quality cam pic, stick with OOS stock cam app. This has been true since OP2 era.
