If I buy the Unblock tv box, next time when analog signal no more can I don't buy digital tv box and antenna? I mean just watch ch8 those local free channels using unblock tv can or not?
If I want to connect unblock tv box to TV and also digital tv box to TV, how to connect because my TV only have one HDMI connector? Is there some sort of device make one TV HDMI slot to become 2 slots or more? Dont want to everyday plug in plug out HDMI wire.
Any reviews between unblock tv vs minix, which better? Does minix inside have something similar like the ubtv app inside unblock? ubtv app seems like the main good feature of unblock.
Thanks
Makes absolutely no sense for you to get ubox just for the mediacorp channels.
1. In terms of cost, the cheapest ubox gen 3 costs around $130-140. A simple digital tuner + indoor antenna costs $50 max on qoo10.
2. In terms of picture quality, with digital tuner you can receive the channels in 1080i quality if your tv supports fullhd. The picture quality of the channels in the ubox livetv app are pretty terrible(probably max 480p).
3. In terms of channel stability, ubox live tv channels always go up and down, especially these mediacorp channels in the malaysia section. They might be unavailable for long periods of time. With digital tuner, you dont have to worry about this. The only consideration would be where to place your antenna for best reception and this is easy with some trial and error.
Dont bother considering brands like minix or evpad. They cost more than a ubox. For your usage purpose, you really can do no worse than getting a standard digital tuner and indoor antenna.
