- May 3, 2001
i am using google keyboard to avoid this problem
Dun want, I dun like Google Keyboard.
anyone has this problem? The headhone indicator keeps coming on in the status bar. This causes the proximity sensor to not work. When making phone calls, the screen doesn't go off, and my face will come into contact with it and activate certain functions.
Dun want, I dun like Google Keyboard.![]()
What's wrong with Google keyboard?
anyone getting the playstore can only download via wifi (error 409)?
Singapore's Redmi 4A is also 32GB storage but 2GB of RAM only![]()
Buy Redmi 4A @ $169 and free 5000mAh powerbank
http://www.lazada.sg/mistore/
Source:https://www.facebook.com/pg/XiaomiSi...45817955459299
" Visit us at the Comex Show 2017, Booth 8420, Level 4, Suntec Singapore Convention Hall between 31 Aug - 3 Sept for great Mi accessories promo! Promo is also available at Mi Store @ Lazada, and Authorised Mi Stores (Suntec & Causeway Point) during the same dates! All promo items and bundle gifts are available while stocks last. "
But Xiaomi India just launch a 3GB Ram / 32 storage recently, which is better.
Source:http://gadgets.ndtv.com/mobiles/news...ations-1743327
Redmi Note 5A will be coming in 3GB+32GB configuration soon, under the name of Redmi Note 5A Prime~Woah the Redmi Note 5A got only 2GB RAM & 16GB storage, seems like their technology is going backwards.
4th Quarter of 2017, Android operating system minimum requirements with customized UI (that is not pure Android) should be at least 3GB RAM, 32GB storage + dedicated microSD expansion slot.
What's the rationale for such configuration? Puzzling..
Ok noted . Thank you ..Redmi Note 5A will be coming in 3GB+32GB configuration soon, under the name of Redmi Note 5A Prime~
https://www.mi.com/sg/redmi-note-5a-prime/
Xiaomi Mi 6 seems to be the one you're looking for..Ok noted . Thank you ..
So far Mi.com still have no device in 5.2" size & the three Android navigation touch buttons below the LCD screen.
That is, Not the on-screen sort of touch buttons.
Are there any one-click root and unroot programs/apps for this phone?
I tried many, from KingRoot, KingoRoot, One-Click-Root, etc but they all dun support.
Are there any other one-click root programs I missed out?
Thank you.
Oh really, thanks. You know their products very well.Xiaomi Mi 6 seems to be the one you're looking for..
Has a 5.15" display, with capacitive touch buttons below the screen(not OSK). The home button is integrated with the fingerprint sensor.
