GPU temperature.
stickerbomb
Hi, I've been wondering if my gpu is running too hot as I keep having a notification from NZXT's cam software saying my gpu is running at 83 degrees which is not very good for the gpu.
any advice?
koroshiya8
what is the fan speed? scully u accidentally put manual and very low .
stickerbomb
i tried to tweak the fan curve instead of leaving it at "Auto" in the Asus AI3 software.
However when gaming, the fan would suddenly spike and spin damn fast and loud then suddenly back to the usually "medium-ish" speed.
i'm wondering if my graphic card is about time to up lorry šŸ˜”
but i'll try your settings again. the frame rate i'll adjust in the dota 2 in-game?
Limit your frame rate to monitor refresh. 60fps to 60hz,120fps to 120hz, etc.
Tweak more aggressive fan curve. 30deg to 25%, 40deg to 40%, 50deg to 50%, 60deg to 65%, 70deg to 75%, 80deg to 100% fan speed.
Then monitor the Temps again when you're playing Dota.
Sent from Overpowered Phone Mark III using GAGT
hlots123
is there a gpu temp monitor graph? check if there was a real gpu temp inc associated with the fanspeed inc...
mnemo_05
what case are you using? do you have enough airflow on the GPU? considering that your card aint a blower type, the heat is being dump inside the case. if you dont have a good enough circulation, your card will simply suck that same heated air back to the fins.
stickerbomb
i'm using the phanteks P400 tempered glass. I've 2 fans at the top and 1 at the back. all exhaust out. then my kraken x62 is mounted at the front. 😐
stickerbomb
when i start the game, you can hear the gpu fan getting louder then from the software i see the temperature being in the 65ish range but when the game starts, it rises to 80ish and hover around 81-84 degrees until i close the entire dota software. 😐
Has it always been this temp or gradual increase?
nexusRAGER
maybe is the Cam software issue?
Mine recently keep having notification that my cpu and gpu usage is100% when i am in dota. it has never happened before
stickerbomb
yes. according the the software, temps remain around that. and according to my ears, i can hear the gpu fan spinning fast-slow-fast-slow. then i changed the setting of the gpu fan speed back to "auto" in the Asus software then don't have this problem but the gpu starts to run hotter (higher by 8-10 degrees)
then fan spikes up/down, temps remain 81-84?
stickerbomb
i'm suspecting that too. cos to be honest the Cam software is buggy af. the in-game overlay would also shift to bottom right all of a sudden when playing. šŸ˜”
but the problem is my gpu fan would spin a lot louder means it's true that my gpu is running hot isn't it?
could it be a problem with my cpu case? meaning Phanteks P400 got poor ventilation design?
hlots123
cud be some kind of sensor collision between cam & aisuite, try removing cam to test as others suggested
or, if ur custom setting has sharp fanspeed increase to 100% fan at 82-84c, then its ur setting - see if u can set temp hysteresis like 3-4c
