5. Functionality and features
Ports
It is 2017, this is a cheap TV, and yet this TV still provides a plethora of ports. Composite and component video are still available, when some TVs have already gone HDMI-only. These analog inputs are still needed for old camcorders, DVD players, and gaming consoles without HDMI.
4 HDMI ports is about what is necessary nowadays. TV, smart device (Android box, streamers, or in my case a computer), gaming console, and one for other stuff. There is even MHL support on one port.
Audio out, older TVs have only analog, newer TVs have only digital. Why not both?
There will come a time where all amplifiers have a DAC inside and all audio connections are digital. Now is not the time.
This TV has Wi-Fi. But Wi-Fi is for the weak, so there is a LAN port also.
1A of USB3 connector for your streaming and charging needs.
Settings
Something tells me this product is imported from Malaysia. Something tells me the manufacturer never intended this product to be sold in Singapore.
Very useful audio options. Some TVs' (Heck, even some STBs) audio out is fixed. Some TVs' audio out is variable. And sometimes you need one and not the other depending on the setup. This gives you the choice.
Always good to have a TV that can either output RAW or PCM.
Nothing groundbreaking, but stuff that are good to have.
Anything above Sharpness 0 applies sharpening filter. Leave at zero if using with computer. And leave at zero for pretty much everything.
