[Official] Chromebook SG
Intrinion
Senior Moderator
Senior Moderator
Aww. D:
Parts should be hard to get from Simlim.
Hmm. Is it a battery fault? Your best bet would be parts from Amazon and self replace.
Do anyone knows where can I do a repair for my Chromebook?
My Chromebook cannot detect my battery. :(
K202020K
Try to Google for :
1. Any online tech support forum for your Chromebook model, or
2. Search for diagnostic tool to aid the trouble-shooting. Maybe it's just a software configuration.
Also do check out Amazon on your particular model or similar models from the same maker. Sometimes the model's review section may provide some clues, or you could include your review & this battery issue you have. Some Chromebook experts may respond with their solutions.
As for SLS, can forget it as these people are just interested in selling machines with fat margins.
Can search YouTube, iFixit & other similar tech repair websites for solutions. But first of all, do check out its user manual for troubleshooting tips & any online references, support forum, email support availability etc.
Sent from Osaka, Japan using GAGT
generalwu
Sad, after looking around I think the most likely scenario would be a mothboard failure (According to this source: link)
The cost of replacing the motherboard are around US$110++, which I think is not economical (Link: here).
Guess I'll have to used it with power plugged in (No longer portable). :(
yusoffb01
for battery problem, just unplug the battery wait a while and reinsert
if someone has similar model can try your battery on their laptop
K202020K
Yes. Remove the battery, clean up the battery contacts, then re-install it back. But do make sure the machine is isolated from the mains, during this operation. Unplug the power adapter too. Good luck bro..
Sent from Tokyo, Japan using GAGT
hawthorne
Chromebook batteries normally not removable, unless u remove the casing. See can download the service manual to guide the removal
Henry Ng
Last time it was carried by Courts.
I remember saw some of the chromebook, but recently i want to buy one and found out storewide don't have chromebook anymore. WTF!!
HN has HP chromebook at $200+ and 1+4 yrs EW is $108.
rAcEr
Which HN is this? I am trying to find a demo set for Asus C202SA but I've not come across any shop in Singapore that sells this.
I guess it is almost impossible to find physical shops that carry a wide selection of chromebooks in SG.
Henry Ng
HN at square 2 has HP chromebook. I intend to buy in December. Can call them to ask.
Henry Ng
Just to update, HP Chromebook 11 G5 is available at HN square 2 at $399, 1+4 yr extended warranty at $108. Now 1 new set only.
K202020K
I think 11 is too small and waiting for 14 to drop price. Can get from HP online store.
Yes, if you get 11" C-book, you'll need to connect an external monitor for extended usage, otherwise your eyes will be under heavy strain.
If Google don't move fast enough, they might lose out to the up & coming Windows 10S, Microsoft's version of Chrome OS, although it's rather unlikely this stripped down version of Windows 10 would be capable of built-in antivirus protection & seamless, hassle-free updates.
generalwu
Chromebooks in SG are way overpriced.
I rather get it from Amazon (Especially for their open-box sets).
I actually preferred to use 11" for portability, 14" is just too big to bring out. =:p
TBH, if they're going with UWP and the Window store then I might give it a pass.
Later become the next Surface RT. :s13:
Intrinion
Senior Moderator
Senior Moderator
I think there is still an appeal for Cbooks.
The 10S imo is basically a restricted version of Windows limited by software (restricted by a license). Hardware wise (if it comes with X86 /non arm components) it is more than capable of running software out of the Windows store.
But it's restriction is restrictive and unless imo is properly priced ..and strictly enforced by partner OEMs, will be a white elephant.
Take for instance a Lenovo 100S or Asus H200A - these with full fledged windows are priced attractively already.
generalwu
Do anyone know how well does windows 10 perform in low-end processors?
Last I heard they're sluggish and barely usable. :(
generalwu
@sendtolee Lol, if that's the case then never mind, Intel m3/i3 would be my bare min.
In fact for Chromebook the N processor's are not smooth enough for me, min U processor or m3/i3 processor. :p
