Air conditioning - Any recommendations please??
Kaylin
can anyone tell me what BTU i need based on my floorplan?
mines a 3 room BTO with the red part of the bedroom hacked to convert into a bigger living. there will be no door at the kitchen. my hubby wants to turn on all the aircon at the same time and he wants the toilet to be cold as well (weird i know) meaning he doesnt want to close any door. we're thinking of having a 24K one at the dining area wall, and 10K at each bedroom. also, 2 compressors. one 24K the other 20K. would that work? most likely going for starmex. thanks guys!
terumo
1/4 inch thickness for drainage pipe is sufficient.
I just spoke to cool engine.
The lady said that 1/4 inch insulation for the drainage pipe is sufficient. It will cost S$250 to upgrade it to 1/2 inch insulation for the drainage pipe. Is it worth to upgrade it?
terumo
Lowest energy consumption will be Starmex 5 ticks.
There is a Daikin 4 ticks 3MKS50FSG if you use 2 units most of the time.
Hi guys...
Have been lurking around this thread but I have been struggling to decide on this quotation by Cold Engine. I just bought a resale flat and am contemplating on which of these 4 systems is the best:
Mitsubishi Starmex system 3 - $2850 (2 ticks)
MXY3A28/MSYGE10 x 3
Daikin inverter system 3 - $2950 (3 ticks)
3MKS71FSG/FTKS25DVMx 3
Mitsubishi New Starmex system 3 - $3400 (5 ticks)
MXY3G28/MSXYFJ10 x 3
Daikin smile series system 3 - $3350 (5 ticks)
MKS80QVMG/CTKS25QVM x 3
Can experts please advise on this? :(
I don mind paying a bit more for efficiency as I project I will be using the air con quite a bit. But I heard that 5 ticks uses a smaller compressor.
Easy to maintain, quietness and comfortability is key to me. Sometimes I might even off the aircon if the weather is cooling.
On the other hand, there will be one room which will be underutilized. only 2 rooms will be utilized. So what is the better option?
Some say Mitsubishi is better due to spare parts easy to find and install. Some say Daikin more durable. Read until quite sian already.
terumo
Can work but need additional power point & have to see if your ledge have space for 2 compressors.
aosw88
try contact cold (not cool) engine, got free upgrade.
I typed wrongly. I contacted cold engine. they say that 1/4 inch for the drainage pipe is sufficient.
The free upgrade is only for the copper piping. Did anyone get free upgrade for the drainage pipe?
Vervain
MXY3A28/MSYGE10 x 3
This is good enough and lasting. I installed this for my home 1-2 years back.
Can refer you to my ex boss (air-con co) if you want but I think may be slightly more expensive. Using 1/2" copper piping and insulation shouldnt need cost so more.
My boss contractor installed mitsubishi fujitsu daikin and he tells me the above system almost got no complaint case. Not advertising...just sharing.
Some $$ cannot save. Very important to find reliable contractor to do a proper job to prevent gas leakage...especially the insulation.
FinalTidus
MXY3A28/MSYGE10 x 3
Nice! I am thinking of this one. But I am wondering about the cost of energy consumption since it is only 2 ticks.:eek:
Yup but is Cold Engine reputable? Was comparing between GC and this.
FinalTidus
Thanks!
But I decided to go for this:
MXY3A28/MSYGE10 x 3
FIRETRUCK
Hi,
Cold Engine quoted $2750 for Daikin inverter system 3 (4 ticks) 3MKS50FSG/FTKS25DVM x 3
Chanced upon Mitsubishi Starmex system 3 (2 ticks)
MXY3A28/MSYGE10 x 3 but had not contacted for pricing yet.
I'll only on the air-con about 3-4 times/week, may I know which should I go for and why?
Thanks!
Hang_Terra
Same dilemma as you and after research I am going to go for the Daikin 3 ticks. 5 ticks will take too long to recoup the premium paid for our low-mid usage.
I read that the Starmex had some QC issues recently (of course this one is based on luck) and the fact that Daikin has an extended warranty promo on the FCU pushed me over to their camp.
Hi guys...
MXY3A28/MSYGE10 x 3
FinalTidus
Oh man...
So Starmex now has QC problems? :(:(:(
Jialat liao... Should I change to Daikin?:(
yc1979
Which brand is more reliable? Cos most of us will not like to change aircon every now and then.
So, i think reliability is very important.
Globe
planning for my 4 room now.
been getting mix advise because my LR i plan to put one, so i am looking at a system 4 (3 BR & 1 LR).
One concern i have is that my kitchen wall will be hacked away, so the space itself becomes alot bigger.
By using a system 4, i scare it wun be cold enough when i turn on the LR one. However, i foresee it being used only on big occasions where there is a party or gathering in the house which is few times a year. So it doesn't make sense to have 2 units in the LR.
d3n
Oh man...
maybe referring to the newer 5 ticks model...
the 2 ticks model is very reliable... previously 4 ticks but downgraded to 2 ticks due to new regulation.
humanrace
Me also went for starmex 2 ticks. Low usage though. Should suffice.
Chuck Norris
Hi guys, need some comments on what I've just been quoted...
System 3
01 unit - MXY-3A28VA (30,366BTU)
03 unit - MSY-GE10VA (9000BTU)
Price : $ 2,799 nett
- 1/2 AMAflex class 1 insulation
- 23 SWG copper pipe
- 16MM drain pipe
- Keystone cable
OR
System 4
01 unit - MXY-4A28VA (30,366BTU)
01 unit - MSY-GE13VA (12,000BTU)
Price : $ 3,800 nett
- 16MM drain pipe
- Keystone cable
Thanks in advance! :)
FinalTidus
Hmm okie. Just don't want to regret this. My very first home. So every big item purchase matters.
HoGnix
System 3
- 16MM drain pipe
- Keystone cable
OR
System 4
- 16MM drain pipe
- Keystone cable
For the System 3, IMM one shop A*** selling 2699 nett with similar configurtion.
except AMAflex is class 0 insulation ( class 0 is better than Class 1 ).
go for it if you OK with the workmanship for that shop ( see online forum comment).
Personally, I Just changed the 12 Years old system 3 Fujitsu air-con to the new Mitsubishi system 3 (2 ticks) one and installed yesterday. both are get from that shop.
My 12 years old Air-con never give me problem until last year it need top up gas one time. but recently it shows the sign of the gas no more again, so I reckon there must have leak somewhere in the system. after considering the repair cost, the age of the air-con and old non inverted compressor, I decided to get the new system 3.
Asus80
System 3
- 16MM drain pipe
- Keystone cable
OR
System 4
- 16MM drain pipe
- Keystone cable
22 SWG copper pipe more better
System 3
only $2650
go to facebook find Jex Aircon
https://scontent.fsin2-1.fna.fbcdn....84058_6071125774375_5464627336131379200_n.jpg
shadow99er
I'm planning to get a new aircon to replace my old aircon. Currently using a non inverter aircon.
There are no leaks for pipes and cables.
If I were to replace with a new inverter setup, can the pipes be reused?
Shortlisted Toshiba and Panasonic system 3. Salesman said Toshiba system 3 compressor is made in Thailand. How true is that?
