Xiaomi Mi Max - Part 2
kelvinti
Thanks for this. Have this issue of Spotify refusing to advance to the next song unless I open the app, wondering if it's an app issue, or a phone issue, or otherwise.
It could be battery and background setting issues. Certain apps need to be "free" from MIUI battery saving and background job conrrol optimization.
There are few battery and background settings that can be changed to bypass such apps issues.
i1magic
Anyone has done any research on whether is Mi Max 2 worth it? As in comparing to MI Max 128 GB at 319 vs Mi Max 2 at ard 419 (after discount etc).
Main tussle is whether is it worth the cost difference. Thanks.
Mi Max 2 available for sale already? Where?
cokiee
Can I ask where please? Right now I've 'locked' the app in the tray, haven't tested it out yet. But if it persists may have to try other solutions.
Lil_d3viLz
My phone tio locked how ah?
Fingerprint doesn't work because of first bootup.
Password doesn't work =.="
I didn't change my PIN
kelvinti
Change these 3 settings:
1. (Battery and performance):
> This is a global setting, meaning the whole phone and all apps. I set it to OFF as the 4850mha battery is more than enough for me. I don't need any battery saving.
2. (Security > Battery):
> Spotify app only
3. (Security > Permissions > Autostart):
> Put the Spotify app into Autostart
Last but not least, reboot your phone after that.
cokiee
> Spotify app only
Whoa, thanks man!
Krabs.
qoo10 newstar start to sell/preorder mimax2 ... price is ~$100 above the china price direct exchange rate
youtube search "mi max 2" filled with fake videos clickbait
*just noticed there is a mimax2 thread outside , will continue discuss there
gctmls
Hi fellow xiaomi gurus, if the mi max is shippied from china can buy ? Without warranty.. saw one shop selling around $200 after coupon.. but not sure reliable anot. What's the diff between export n local set ?
Krabs.
what capacity ? if 2/16gb it's not a good price ....
local set you get covered for manufacturing fault during the first year .... if you drop or crack the screen it's user fault not manufacturing fault
tradeoff is ~50% higher cost than the promo price of export sets
export set means u leave it up to luck .... what matters more is the firmware inside is china rom or global rom
