idjekyll
- Apr 30, 2006
ask u all for air con mounted on the wall if the bed is directly below the aircon can the cold air blow onto you when sleeping or must put diagonally opposite the aircon?
My bed is directly below a unit and it hasn't been an issue once. Make sure you sleep with your head closer to the wall below the unit so you don't get the direct hit of the cool air. In that position, even if you have the swing activated, it won't affect you. Tried and tested. One minor issue is to take immediate action when the unit leaks.
