Internet VLAN 10 prio 0
MIOTV VLAN 20 prio 4
You're welcome : )
how about the tagged and untagged?
i've seen alot of conflicting instructions online..
You VLAN no profile meh? Why need manual config one?
Tagged for both
the presets don't work![]()
Why don't get Asus routers? Preset all ok one : ) good performance also, you try my settings ok mah??
How come you need to do it in manual part when the above post already mention the tag and priority..
Me too... Sick of ASUS...i switched from ac87u to synology
sick of asus
always got problem with it.. ac87u was especially bad.
Hi Nitrile
Did you ever sort out your RT2600ac issue with Singtel?
Can I ask how are you liking the RT2600ac? Would you recommend it?
There is a sale at Storage Studio for $329 and that looks like quite a good price.
Doesn't work.
Had to buy a managed switch and did VLAN tagging on the switch for my Singtel TV to work.
Synology Rt2600ac does support vlan tagging since firmware v1.0.1-6007.
Synology even wrote up a guide on vlan tagging on its website. How can it not work?
Do note singtel tv needs priority 4 to work. Or else it won't. Make sure you plug the Singtel tv connection to the assigned ethernet port too..
Hi Nitrile
after reporting the issue to them in early july, the issue has finally been fixed in the 24 august firmware..
use singtel-others preset and singtelTV will work flawlessly.
guess i can get rid of my managed switch already.
