Nvidia Shield TV
jayz_sg
thanks.
will try that soon. but for now, i keep having DNS failed on getflix website itself even after configuring on both router/pc with no issues. could it be their downtime momentarily?
If the DNS status shows as failed, that means the setup was not correct. Check your DNS settings on your PC again and make sure it is the one from Getflix.
https://www.getflix.com.au/setup/dns-servers
Also check that your IP is correct in the dashboard, if the registered IP and current IP is not same, do a force update.
imacbie
thanks.
u can force update your address within your account dashboard on the site
maybe dynamic ip changed
Fiddler
Finally got my shield and set it up….works well enough….bit of stuff i need to get used too.
Remote sucks major balls tho….using a Minix A2 Lite air mouse instead…works well enough in Kodi etc but on android apps the Minix A2 Lite won't input search characters….annoying using 2 remotes.
anyone found an air mouse that works fully?
KriBKriB
eh i think all boxes comes with a set of international adapter for the main plug. UK or EU
no other things needed.
Could someone confirm that Shield Pro boxes bought from the US come with UK plug? Do they support both 220/110 Volts?
Thanks!
phrozact
I got my set from Amazon US, but needed to use my own adapter to plug into our socket.
thorsten139
Any pros know what DVB-T2 receiver to use to connect to the shield?
my TV don't have dvb t2 but i want to connect it directly to the shield and use plex
tatsit
High Honorary Member
currently what's the best way to get shield?
and also just to confirm, has anyone tried the 4K HDR 10bit + dolby atmos with shield?
987654321
arghhhh damn irritating, on the product page it says ship and sold by Amazon and able to ship to Singapore, but I can't freaking check out!
