China Tablets to recommend
motomage
Haha, I didn't do my research before buying. Much of an impulse purchase, seems there is only the 4/64GB version in the market. Sorry for the confusion.
Anyway, used it during the weekend. Nothing heavy, watched lots of Youtube, stream movies over my home network, internet and read some magazines online. So far very stable and smooth. No hangs, hiccups or restarts from the custom ROM.
ahh, okay, i intend to use it for Youtube and steaming movies as well. And maybe play mobile legend.
Good to hear that its holding well for you. I might just get custom rom, will read up whats the difference between custom and official ROM and decide again.
fat_boyz
Anyone heard before this brand called Uniscom/紫光电子???
I quite like the specs of their 10.1' MZ65plus phablet...
My sister who's now in Beijing received our two Uniscom MZ65plus phablets today:
free gifts:
She said quite smooth to use... I won't get to try until next month....
Feedback on TB seller site very good... for those who want to read reviews can see here:
https://detail.tmall.com/item.htm?i...u_properties=10004:1548740603;5919063:6536025
motomage
yusoffb01
Anyone can recommend a tablet running on Windows? Budget around $150.
Thanks!
not much choice.
for quality but no microsd card, get mi pad 2
all 8 inches have like 3~4h battery life.
onda has bad qc.
for me i bought iwork 8. use it to remote into home desktop. also works fine for web browsing and office side by side. can charge while using
newer iwork air has full hd i think
Franky37
not much choice.
onda has bad qc.
I don't need much requirement. As long got 2gb ram and 64gb storage (expandable or not).
Mainly use to run some software program.
Mi pad 2 run on windows?:eek:
benzene
I just bought a Chuwi Hi8 Pro yesterday. (paid about USD98 from Aliexpress)
Planning to use only window.
Done a bit of research online, plan to delete the android partition.
Is there any easy way to expand the partition and link it up to C drive?
Basically the only program I need to install is office 2016.
not much choice.
onda has bad qc.
yusoffb01
yusoffb01
The complain about chuwi is that they switched to low quality flash chips. to test if you get a sucky one, run crystaldiskmark and hopefully above 80MBps
benzene
Yah I saw the review on youtube.
Basically as long as I can check and reply my email is already good enough for me. Is basically a tablet when I bring for business trip.
I have a surface pro and a teclast x98 plus II.
somehow I convince myself I do need an 8" tablet.
