Idling with AC
hoboonhua
Sorry another noob question,
Leaving the car idling with AC e.g 1 hr will harm the cat or not?
IcYFl4mEz
I believe it wont harm the car as long as u got good coolant
superman
People sometime stuck in causeway for 3hrs, don't see any problem, just make sure your cooling system is ok.
EJB
must be wan to piak piak inside car rite ? do in at midnite if dun wana get caught & car will be much cooler..
The heat inside will fog the glass.
Ooops. Take it as I never comment.
skai_11
Remember to wind down few cm of your windows for fresh air. Although modern cars has lower risk of carbon monoxide issues, you would not want paramedics to see you and your partner naked while attending to you
Sent from using GAGT
AL5509
Why u all so dirty... i was thinking to take a afternoon nap during lunch hours...
Hhhmmm think you should be worrying about yourself being in the car while asleep than your air con system?
http://goodyfeed.com/sleeping-in-a-car-with-its-air-con-on-will-kill-you-herere-the-facts/
Myth?
I dont know but worth risking it even if there is 1% this could happen?
carloverme
No it won't.
I have a Ultra Gauge to read the Cat temperature.
It stays very low when idling.
No problem idling for 1 hour while having petting with GF
