[Advice] Recommendation for AMD Gaming PC
ChouunShiryuu
Looking to get a AMD Gaming PC. Not looking to overclock. Can play Sims 4 in 1080p, Youtube, Surf Web, Use Photoshop.
Only need the CPU and does not need monitor, keyboard or mouse.
Budget 1.5k and will up if needed. Would prefer the motherboard to have decent audio quality. Asus?
AMD Ryzen 5 1600
GTX 1060
Tecware Alpha
Samsung 850 SSD 250GB
Windows 10 Home
Asus DVD-RW Sata
Any recommendations for those missing parts? Thanks in advance :)
singupingu
CASE: Tecware Alpha $79
MOBO+CPU: Asus Prime B350-PLUS + AMD Ryzen 5 1600 $488
RAM: Corsair Vengeance LPX 3000MHz 16GB Kit $219
PSU: EVGA GD 650W $129
SSD: Samsung 850 EVO 250GB $259
HDD: WD Blue 1TB $72
GPU: *error 404: gpu not found due to oos*
OS: Windows 10 Home $11 via carousell
OSD: Asus OEM Internal DVD Drive $25
TOTAL: $1282
Prices quoted from PC theme or otherwise stated.
Sent from PM me if you wanna build a DIY PC or wanna learn how to make one yourself :D using GAGT
blurfish29
No GPU how to operate this ryzen system 🤣
TOTAL: $1282
Calikura
Lazada has a few 1050Ti going for.. eh.. so-so (high but not insane) prices. Can get one in the meantime, to wait out the current shortage, and then upgrade later if needed.
ChouunShiryuu
Why do you need a DVD ROM
Need a DVD player to install softwares.
Not really keen on 1050. Will wait for stock to arrive if Pc Themes or other stores Oos.
ChouunShiryuu
TOTAL: $1282
Don't really need WD Blue as I can reuse my old one. Windows I intend to get at the store.
singupingu
Parmesean
Is the audio quality on Asus Prime B350-PLUS good?
Or should I get a sound card?
If you're an audio enthusiast, please get a sound card.
The on board audio sound card is only good to a certain point for normal usage only. Don't think it's good enough for audio enthusiast at all
Agreed, if you are just doing light gaming, or even some light music editing, however, if you really need a sound card i would recommend going for an external one.
tigerwoods
RealtekĀ® ALC887 8-Channel High Definition Audio CODEC
Good enough for normal users. Can always add a soundcard if u dont like the sound.
undead102
For normal average user for normal everyday usage onboard dac good enough. If you have an expensive headphones or speakers then it is recommended to get an external dac amp combo to bring the most out of your audio setup.
If you are using <$200 headphones or speakers then the onboard dac is good enough most of the time you might not be able to hear a difference with dac or not.
Focus on getting a good headphone or speakers before thinking about investing on a good external dac amp setup.
