Aia vitality app challenge
blurpandasg2014
I just downloaded the aia vitality app for weekly step reward program. However, my shealth does not seem to auto sync the steps.
Does anyone know how often does the steps get updated to aia
dendii
Your shealth should be the main tracking app and the data is usually synced at the end of the day or the following day. (In my case, usually before 12pm).
However I have also experienced server lagginess on multiple occasions. The tech team got back to me saying that it may take 72 hours for points to be properly reflecting.
blurpandasg2014
So far there has no sync history since I started using the app since 2days ago. Is there a manual sync button?
zhix
My S Health can't sync to the vitality app since Day 1.. about a month already, app shows that my S Health is already linked but no data is transferred. Write to AIA support team .. totally no response.
blurpandasg2014
Reinstall Shealth and AIA app. Afterwhich, u try to sync. Once u see that there is a sync timing means the data is uploaded to AIA side. If the points not updated on the app, it means its AIA server issue
zhix
Tried 3-4 times .. doesn't work, still no sync. Using Samung Note 5 running on latest Android 7. not sure if that's the issue
zhix
For those who have the same problem as me. This solved it.
Thank you for your email and we are sorry for the late reply.
Please be informed that we check with technical department, as per our technical team mention, there is configuration issue with S-Health. S-Health application allows only in developer mode to get the steps or exercise. Please try to configure as SHealth-->Settings-->About--> multiple click on version number. Then try to de-link and link and sync. Please maintain proper internet connection when syncing.
Should you require further assistance, feel free to contact us at 1800 248 8000 or send us an email at support@aiavitality.com.sg.
Real change to health begins at AIAVitality.com.sg.
Yours Sincerely
Vitality Support
chopra
sidetrack. anyone flash his vitality card at e counter before? wondering what food is entitled to further discount
zeroX26
You can DL the list of food items on the Vitality website. But the discount isn't given on the spot; the value will be accumulated and paid to you via cold storage vouchers.
The_Davis
High Honorary Member
Deluxe Member
Look for items with "V" at upper right corner of the pricing tag.
E.g. essentials 10+ 2 eggs
SBC
Can help to take a snapshot of the price tag?
How to upload the workout using app like Fitbit for additional points? Thanks
Wkheyk
does it means that those with a "V" will then be entitled with the points?
is it okay if i show the soft copy of the vitality card using the app rather than bringing the physical card?
Wkheyk
anyway, for those facing issues with syncing the app and device, you can try to delete the app and re-download again to see if it works
arunjacob
Looking to join team
I am looking to join a team. Hitting the target every week. PM me.
