HTC U 11
jyaisu
Any ideas when Solar Red would be available?
Tried checking with Singtel but they told me that even the local HTC supplier have no idea :(
Jeanbob
Warranty voided if bootloader is unlocked
For those who were still unsure:
Rubick
Do you all use double tap?
Sometimes the phone like will go into deep sleep then wont respond to the double tap till i squeeze the sides.
Conan1986
Ya, it happens to my phone as well. Apart from double tap issue, it also fails to detect the "Ok Google" hotword and I'll have to restart for it to work again. Minor issue but kinda annoying
den_tay
HTC U11 ( Double Tap Problem )
Yes my also got the above problem and i have already sent in to HTC Svc Centre and get them to check. All the four checked boxes if checked it still not working at all for my set.
Rubick
Seems like a software bug more than hardware. Hopefully it will get fixed in the next update
Conan1986
Yep, most definitely a software issue.. hopefully HTC push their update to SG soon, HK with the same SKU (400) had received update earlier this week.. feedback is that shutter lag has improved..
m3csl
Hi, anyone has problems with using a normal 35mm earphone with the enclosed type c adapter with the phone?
I tried a few earphones and some can work and some cant.
And does it support mic function?
Thanks!
benny888
Thanks!
Gave up testing - all my 3 other earsets sounds simply bad with it. The supplied Sonic piece is superb
sunset73
Dear all, I have joined the HTC U 11 family with a brilliant black set :)
Any idea where to get tempered glass/screen protector for the set? Many places I asked do not carry the SP/tempered glass.
Thanks!
gaityr
Just joined the HTC U11 Club too! Finally managed to buy a silver set from Red White Mobile yesterday... It's been sold out for so long! Good for HTC, I guess... So far really loving the experience. Remarkably smooth and snappy. Battery life seems promising too - I'm on my first full charge and have clocked up almost 2 hours SOT with 71% left.
Now just need to go experiment with the camera and hope it really is better than my Nexus 6P!
batboyz
You may not be overly satisfied with what you will discover. IMO, it is not better than N6P. U11 image processing still can't beat Google HDR+.
batboyz
OK.. Nexus is dead.. Please move on..
Huh? How is that related? I mentioned Google HDR+, not just Nexus. The new Pixel will have improved HDR+. You should move on rather than boot looping.
In addition, saying Nexus is dead is wrong, why? There are people who are still using them, even Google devs are also still using them, especially for testing. As long as it is still used by anyone, it is not dead. It is dead when it does not exist anymore.
Innovator2409
Any bro here selling his black HTC u11 at carousell, only used for 2 days, if yes can I know y so fast want to sell off? Not good?
