[Official mITX Build Discussion Thread]
TrueBeliever_jh
Nope not threaded.
Think case fans are also not threaded. At least from the one I have seen so far.
lkong
Nope not threaded.
yeah..i have 2 coolermaster 12cm fan used since the AMD opteron time and want to reuse them. but see no threaded hole, end up using some wire to secure it.
in this case, maybe i will go find some thin nut to hole the screw
thanks
TrueBeliever_jh
Not sure if you know or I misinterpreted, but case fan all don't have thread iirc. The screws are self-tapping screws, so they are meant to cut into the plastic frame of the fan while you screw them in on the chassis.
Sent from PM me if you wanna build a DIY PC or wanna learn how to make one yourself :D using GAGT
think some fans come with rubber corners.
my Fractal Design HP-12 comes with those.. can never screw in tight completely
but compared to plastics, the rubber is easier to screw in.
lkong
When i used these 2 fans previously, it was in my CM 5 casing, and it came with threaded holes just nice for the fan. The node 202 holes also fit just nice for the fan, but minus the thread. This is my first itx and it has been a while since i get a pc so i am not sure whether this is the norm or not.
i think i will just find some way to secure them. thanks for the info-s
deadravel
wow. mitx fans here signing in
my very normal spec:
CPU| I5 6500
Mobo| MSI H110I PRO AC
GPU| ZOTAC 1060 6GB
Memory| Crucial 8GB x 2
Storage| Sandisk SSD Plus 240GB + HGST 1TB
Case| Silverstone RVZ02
PSU| Silverstone SX600-G
koroshiya8
Built this about 2 years ago.. quite fun except inside very cramp :o
Swordsman
My entry level setup.
thanks to singupingu who setup everything for me.
MSI H110I Pro AC
Intel Core i5-7500
Crucial value Ram 2133 mhz DDR4 8GB
Zotac GTX 1070 Mini
Fractal Design Node 202
Sliverstone SFX-L 500W 800+ Gold
PNY CS1311b 256 GB
WD Black 2.5" 1TB 7200 RPM
120MM Fan for GPU Airflow
singupingu
Snakepit
Anyone heard of news for the Asrock itx am4 board?
i understand the gigabyte version is out
old rig died and wanting to build a new Ryzen itx
so far parts selection is
MB : Asrock AB350 ITX
CPU : Ryzen 5 1600
RAM : G.Skill Ripjaws V DDR4-3200 16GB
GPU : MSI r7970 Lightning (reuse)
SSD : Crucial MX300 750gb (reuse)
SSD : Intel 530 480GB (reuse)
HDD : Toshiba 3TB 7200RPM (reuse)
PSU : Corsair SF600
CASE : TBC , probly one of those Fractal Design itx case
Jian19
Wah u order from where the case ? I seem it on chiphell forum
Encrypted11
My mITX build specs and pics below....
MB : Biostar X370GTN
CPU : Ryzen 7 1700
Cooler : Cooler Master Seidon 120V (temp use...might chg)
Fan : Be quiet 135mm silentwings radiator fan, Amd RGB stock cooler MB fan and Corsair 120mm intake fan.
RAM : G.Skill trident Z DDR4-4266 C19 8x2 GB
GPU : Evga 1080ti SC Black
SSD : Plextor M8Pe(G) 256GB (OS)
SSD : Samsung Evo 850 1TB
HDD : Pending
PSU : Corsair SF600
CASE : Sunmilo custom chassis: "Red Dragon mini" aluminum chassis tempered glass
Nice build :s34: stock RGB cooler overlaying the AIO pump?
limjialok
CPU| I5 6500
GPU| ZOTAC 1060 6GB
I have the same case, how do u fit a HDD inside? It only have space for 2.5". I tried putting it next to gpu but I can't screw it in place. Was thinking of changing my case to a core v1
wizardundo
CPU : Ryzen 7 1700
HDD : Pending
PSU : Corsair SF600
This case is so beautiful! :love:
I hope local distro will bring in such cases. :s12:
Encrypted11
Recent update to my Fractal Design Nano S
Minibricks dragon assembled
(Thanks Corbell/MSI), unfortunately not a lot of space left inside the case :s13:
