the ONEPLUS 3
storm913
No idea, may be happened due to multiple drops.
The focus is stuck or something
I bought a modular on aliexpress for 4.88 USD but i havent test it out yet as i do not have the T2 screwdriver.
Mine still has warranty by Expansy Qoo10, they ask me to ship back but shipping borne by me.. Not sure if I should, later send liao no return :s13:
pilico
They will return one but dont know when.
How much does the shipping cost? If it is expensive, i rather you buy the modular to replace ( only if you are very sure it is your camera modular that is not functioning well)
storm913
Is there any way to be very sure that it is the camera module that is not functioning well? I have tried the camera in various modes and with other apps but still blurry. Front camera is working fine.
Myu~sun
Confirm camera module . send my 3 to MDR for warranty servicing also was mention its common and they replaced the module for me. So I guess 3 n 3t the same ba . same issue .
pilico
if you have warranty, just send it back.
**Read this is want to DIY yourself. I WILL NOT BE RESPONSIBLE!
Things i damaged.
1.battery case ( Small part chipped off) * can be prevent if you are using correct tools and know what you are doing.
2.LCD and middle plate's adhesive (dismantle wrong side)
3.Bezel (the black plastic thingy between the batter case and LCD)
Since my battery case has a dent on it due to previous drop, it doesnt bother me.
Cost for replacement of parts (If you want to change)*Aliexpress*
1. battery case => ~20USD( Gunmetal ) , ~25-30 USD (Midnight. But i cant find it in aliexpress anymore)
2. middle plate and bezel => ~ 10USD ( unfortunately, you cant buy the bezel alone/ or i am unable to find 1)
3. LCD => 100++USD ( Please die die also must not break/ damage the LCD)
Things to pay attention to during dismantling (Warranty will be voided by DIYing)
( I will not guide you how to pry open as it is too tedious. Watch THIS)
1. When prying open the device, i would suggest to pry from the bottom as it was easier for me
*There are 3 layers; LCD, Middle Plate with bezel and battery case.
**The part you should be opening is between bezel(plastic thingy) and battery case (These 2 parts are snapped together)
***If you realize there is any adhesive between the layers you opening, STOP immediately as you are opening the wrong one (I did this and now i have to replace my adhesive. My LCD now is not fully stick to the middle plate)
#Putting back together
-ENSURE YOU DEVICE IS WORKING BEFORE PUTTING IT BACK.
-When putting it back, i started from the top and slowly progress to the bottom.
(Pay attention to the bottom part, speaker and charging port. They are protected/covered by a rubbery thingy. if you force snapping it back, the rubber might shift and block the speaker holes and charging port hole.)
Scherzinger
eh one part of my touch display i think got abit of deadzone
i ran touch test and swipe gotch one horizontal area cannot register touch
how ah?
storm913
Things i damaged.
This is super tedious!! :eek::eek:
Thanks for the write up, I'm finding a spare phone now and will send it back for warranty :s22:
Pepperisk
Eh got qn. One plus 3t can use 4g+ in sg? If can, need special sim?
I using m1 but my sim since like 4-5 years ago never change. Got 4g but no 4g+
koreanlover
Can, no need special sim.
DO THIS AT YOUR OWN RISK.
You need to backup your phone ,flash TWRP and root it.
Then follow the steps here.
To unlock LTE CA is easier than unlock bands on OnePlus 3/3T.
If you only need B3+B7, you can flash Unlock_LTE_CA_B3B7B8.qcn via QPST.
This qcn file will enable B3+B7, B3+B8, B7+B8 on your OnePlus 3/3T.
1. Backup your EFS and modem in TWRP
2. Enable Qualcomm diagnostic mode
3. Enable airplane mode
4. Using QPST to backup your QCN file
5. Flash rmt storage patch for 4.1.x
6. Using QPST to flash Unlock_LTE_CA_B3B7B8.qcn
7. Disable airplane mode
8. Run Network Signal Guru, choose "Clear Forcing" from the menu on upper right
https://forum.xda-developers.com/showpost.php?p=72124902&postcount=1309
The software needed are here except for QPST and QXDM.
https://forum.xda-developers.com/oneplus-3/how-to/guide-unlock-additional-lte-bands-t3519563
jtec14
furyhawk
OnePlus Service Center
Jurong Point Shopping Center
1, Jurong West Central 2
#B1-87/88
Singapore 648886
Operating Hours
Monday to Friday
11am to 8pm
*Closed on Public Holiday
Based on Lazada oneplus 5
We finally have service center?
koreanlover
Have u tried it? Working?
Yes working for me. But 4G+ only appears when I'm outdoors.
The phone can be unrooted after all the steps for banking apps to work.
But Android Pay is still affected due to the unlocked bootloader. Maybe that's why my Singtel Dash crashes since it also uses NFC.
jtec14
Great, will try when i have time...look abit tedious..
jtec14
Thanks, got 4G+ on Starhub for my china set.
Why dun u use magisk to hide the root/unlocked bootloader for android pay?
koreanlover
Last time I used Magisk, then suddenly some apps stop working.
A few days later I found out that Google updated some services and caused Safetynet to fail when using Magisk.
It has happened a few times already.
http://www.androidpolice.com/2017/0...sed-fixes-latest-safetynet-detection-methods/
I didn't really need root so decided to unroot to see if 4G+ still works and it did.
