the OnePlus 5 !!!
garychengjw
Er...I need to compare it with my p10 plus first then see how...
Sent from HUAWEI VKY-L29 using GAGT
Camera wise hands down p10 la. Don't need compare...
G6 to me is nothing special..only the screen look better..op5 is the interface and the sd835 that attract me..
Like that might as well wait for new pixel2. 835, stock android. Probably best camera again. Lmao
Sent from Samsung GALAXY S8 #CoralBlue (SM-G950F) using GAGT
doki81
x3dnd3x
How to get cart coupon from Qoo10 seller arh? :s11:
Never really hoot from Qoo10 before.
osmond19
Anybody switch from Nexus 6p to OP5? 6p camera isn't that great so I can assume that OP5 is definitely better. My far my stock Nexus 6p running on Android 7.1.2 encrypted still running fine only occasionally will hv a bit of slow down... I believe OP5 will fly...
Am I correct to say that?
doki81
Yes...sd810 and sd835...and 3gb ram vs 6 or 8gb ram...even now my p10 plus see to run faster a lot than my n6p.
jackycar
Yes my wife was using 6p and switched to mi5s plus. After the latest OS update 6p really slow down like ****. Google doing what Apple does and pushing everyone to upgrade to Pixel
My wife's mi5s plus runs much faster than her pixel, 6gb ram is a world of difference.
And my op5 runs MUCH faster than her mi5s plus also ;)
Camera on OP5 is really excellent. Shutter speed is DAMN fast. I can capture super clear shots on moving subjects
Alexz_Hong
Is the OP5 camera really that bad?
No chance for improvement with future updates
Sent from HUAWEI H60-L02 using GAGT
It's not that bad la. Overall is good one, unless you like to pixel peep or crop in a lot. Then you'll really notice the image processing, especially at night. There is a chance of them improving it through software update i think since it's mostly just the processing, but it's a huge HUGE gamble that may never happen. For most people it's okay one. In fact the colours and metering are good, and overall still looks nice one. :s13:
osmond19
Probably need to reset and setup it up over again. Usually, after a major update to the Android version u hv to do that and then it will be smooth again.
jackycar
Even before the update, the phone was definitely not super fast like the OP5 also. The ram is a big factor.
I never ever have to close any apps now, like ever. And Doze makes sure my battery life stays good as well if I don't close apps
