highsulphur
- Aug 16, 2011
nope........
I see...Median... household income by himself
But seriously, I just did some rough calculations and it does look possible with median income, but you just can't use it for housing.
For those of you who are going along the VC to MA strategy here, I'd like to point out that you can still top up once a year, subject to the contribution cap, even if your MA might be maxed out already.
This is because, technically, your MA will never be truly maxed out until you reached 55.
The BHS is adjusted upwards yearly, but because CPF credits our interest for each account at the end of the year, the interests from the maxed out MA account is moved out before the new year. It won't stay in the MA to fill up the new ceiling.
So on 1st Jan each year, the ceiling for the MA is adjusted upwards and will allow incoming contributions again until the new ceiling is hit. You can top the difference between the new and old ceiling.
The adjustment is usually around $2k - $2.5K.
Thanks!
Going to VC after I hit FRS.
Then use my OA funds to invest in stocks.
Sent from OPPO F1s using GAGT
How do you do VC to SA only after FRS is met?
I've always thought that voluntary SA contributions are maxed out at FRS.
Can someone clarify?
Roughly what salary would hit this 37k limit?To be frank, by the time your SA balance hits FRS, your salary would have probably reached a level where you are no longer eligible to do VC. Unless you're those buay kan types at work.
104k..........Roughly what salary would hit this 37k limit?
I am confused.
VC cap is at 37k.
There are 2 vc, 1 is vc to ma, tax deductible.
2nd is vc to all 3 accounts, non tax deductible.
It seems you guys are doing vc to all 3?
And I second the idea that we will reach a stage where we cannot vc anymore if our career is progressing properly. The magic income number for this to happen is 104k PA.
You guys can use my excel sheet to calculate the fv of your cpf.
Hi i wish to know what happens when you do property charge and then pass away. Thanks
What I referred to in post 127 is VC to all 3 accounts. But because the MA BALANCE is already maxed out, whatever that would have gone into MA now goes into SA.
Next step is to then do a OA to SA transfer.
Hope this clarifies.
