PCWX App Discussion...
allanzzz
using on 2 device, device A subscribe a thread, device B can see the thread in subscribed but have to click the star to subscribe, then again in order to unsubscribe.
allow to send picture without needing to click save, then go to our gallery to send.
Posted with MI MAX via PCWX
kuma-mon
hi,
okay for this i can explain.
the star icon reference to your local device database. if you click on star icon, it will add the thread ID to your local device database. also, this will allow the app to check if the thread ID contains in your local device database. if contain, it will highlight the star icon.
because you use a different device, this is absent in your other device local database. thus the star icon wont show as highlighted. if you want it to be highlighted, you have to relogin again, this will reimport back the subscribed threads.
hello, could you allow us to set a certain time when the app switches automatically to another theme? or check the light sensor? thanks!
Posted with E6533 via PCWX
hi,
i can but its not really necessary. you can just change to a dark theme on your own, or just use a dark theme through out.
Asphodeli
hi,
but #lazy leh :s22:
how about exposing an intent so that I can automate it using Tasker or other automation apps?
allanzzz
hi,
1) i tried putting the icons on the top and it looks ugly to be honest. the alignment is off. here's how it looks like
2) unfortunately you cant refresh thread at the end of the thread as of now. but i have make it that, as u scroll down and passes through page by page, the last post/last page will be updated, so fast moving thread wont be missed out i guess
Posted with Redmi Note 4 via PCWX
haha I always have the habit of pressing refresh before I get out of the thread
skai_11
Kuma-mon, i noticed that some threads will not return to the exact same post where i stopped reading previously.
This thread for instance, i stopped at post #123, when i come back, it will show me post #118.
Some threads will restart from post #1 again instead of where i stopped at previously
kuma-mon
hi,
1) my app resumes to last seen post, not the greatest last seen post. so for example if you scroll down to post #123, and u scroll up to #118 it will resume back to #118.
2) which version of the app are u at? i have fixed resuming post to #1 when there's a connection error or when user presses the back button before content loaded finish.
kuma-mon
I have pushed an update to the play store.
Changelog:
:v2.0.8
*Added setting to change font size
*Added ability to copy text in posts.
For now, you can only copy partial text in quotes. Give me some time to fix this.
*Several bugfixes and UI improvements
ikebukuro
thanks for the latest update! my eyeballs appreciate the increasd fontsize :)
anyways not sure if this is a bug or how you intended, but when entering a subforum, the little subforum button disappears so I cannot quickly enter another subforum in the same section. this makes it really troublesome to swipe the left menu out and go back.
thanks again!
skai_11
hi,
Ok i have updated to the latest version. Will monitor if it happens again.
Oh, 1 slight request... When replying, can cursor be default after the quote and not at the start of the text field? Is this doable?
Thanks for the continuous enhancement!
kuma-mon
Haha thanks everyone for the support, theres still much stability issues i need to fix to make the app better.
thanks again!
Ouh its not a bug, the subforum menu only appears on the parent forum but not the other subforum page. This will be one of the fixes i will be pushing in future updates.
BlackCube
there's still issue on images not loading. just now I saw encounter one but forget to copy the link. now forget Liao.
kuma-mon
Hi,
yea i know what you mean, i also encounter it. the image inside the post will show as "x", but after i exit the thread and resume image loads per normal. :s22::s22:
kuma-mon
Hi guys,
Need your opinion.
I am thinking of putting random edmw lingo words while waiting to load each content.
For eg:
It will be a different word everytime. I think this might be a good way for people to learn edmw lingo words while waiting. It also part of the user experience i feel
What do u think?
PS: oh yes i will be changing the loading icon to default android one because the current one i feel gives that "slow loading" vibe. And also under white background it looks a bit painful to see. it's also part of the user experience.
BlackCube
Hi guys,
Need your opinion.
For eg:
Each word will be different everytime. I think this might be a good way for people to learn edmw lingo words while waiting. It also part of the user experience i feel
What do u think?
I tot is 151 and refer to sph?
