the OnePlus 5 !!!
doki81
not sure why helium is not backing up my app on my p10plus...now struggling to do app transfer ...
any good recommendation on app backup and restore?
deckcard
From my testing, helium works on restore but fail on backup (how do you restore if you hv no backup right?) on other phones (tested on mi5s, p10, OnePlus 3t/5, g6)
Only phones that it works on both backup and restore are Samsung phones (tried on s7e and s8/+) and the only app data that I'm interested to keep is AXS history so I use only Samsung for AXS. The rest of the apps I don't really care if they cant backup by helium
WhatsApp and Viber now can be backup to google drive (but for their photos and videos, I copy the whole directory of media to PC for backup to transfer to new phones) so it restore much faster.
For sms and calls, I use sms backup and restore, contacts and calendar are in google
Without root, helium is probably your best bet but it's not updated anymore
shichuanhua
Calendar, contact, whats messages, etc..
that means I just copied all the internal storage file to the next phone will do right?
Actually the apps you mentioned don't have to copy anything .
Just enable back up to Google drive in WhatsApp and do a back up .
Calendar/contact will auto sync if you have Google account set up
Only need to copy music /pictures /photo /video
For SMS message there are apps to back up them
If you wanna preserve your app settings can use back up apps found on playstore but not recommended.
kashix
but hor, sometimes i tried to ignore it but still cant help but to notice it haha.
I can see it too, sometimes reading reddit while commuting, it gives me headache but really not so jia lat la, only if you keep scrolling then you'll see. :s13: it looks like the iOS iMessage app when you scroll the messages LOL
lalalalalala
got my set from qexpress at about 3pm, just went down to my neighborhood shop to cut my sim :D
now need to spend like an hour arranging my icons :(
ybeex92
Yah exactly. if reading something sure will notice cos you need to scroll slowly haha.
xinzizu
Thanks for the recommendation..
jackycar
Did my tempered glass with SG fresh idea. Their price and service is really good.
The oem tempered glass vs my original Oneplus is the same quality and almost half the price.
Tried their oem spigen case but it makes the tempered glass pop out, so can't fit :(
No choice gotta use original oneplus Karbon Bumper case for protection
lalalalalala
u bought the karbon case ah can sic how much u paid?
osmond19
Does the oem tempered glass cover the whole screen? How much is it?
doki81
how come u can test...while mine they say no stock to see...but I just place order to pick up at their shop...
Sent from HUAWEI VKY-L29 using GAGT
