China Tablets to recommend
Vincent.Chee
How is it? Interested to know the actual using experience.
My Chuwi Hi13 is here
haven't play with it yet... charging it first...
fat_boyz
just finished installing all the essential software: MS Office, Adobe Acrobat, Chrome, Dropbox...
Speed wise quite quick... smooth.... faster than I expected it to be....
Touch screen is better than a lot of android tablets... The resolution, display color & sharpness is very impressive...
Because of its size, can't really hold it like a small tablet for long... the normal tablet stands I have also can't really hold its weight and size...
Since the one I bought doesn't come with the keyboard... I've ordered a keyboard... it should act nicely as a stand...
Will update on experience after a few days...
skraggle
i still have note 2014 since 2014 and battery life around 8h screen on time. whats the cube t10 battery life like? i would want a tablet that has split screen multi window.
I haven't done a full drain on it, but so far, battery life is impressive. Still really pleased.
leonaheidern
Gearbest really delivered for me when I got my Cube and also when I got the Teclast.
oh I couldn't get alixpress official alldocube store to accept my standard charted unlimited credit card so I end up buying from cube-tablet store direct itself. arrive in 4 working days via DHL.
I wanted a cover and glass SP and order it but the store said it wouldn't fit so canceled it for me.
it's a bit heavy thou hahaha for t10 plus
antutu score is 42354.
was a bit funny that I needed to slot a microsim in before I could sign in to Google account on the tablet.
also the fingerprint reader is the you must press and leave your finger there kind not the swipe kind like Samsung galaxy note 4 so that's a bit new for me.
Posted with Redmi Note 4 via PCWX
makann
how long can it run on a fully charged batt?
fat_boyz
My wife use it to surf net and read ebooks on the energy saving mode... the longest record till now is about 6 hours+... battery dropped down to 20+%
fat_boyz
which china brand running windows is gd for photo editing using lightroom / photoshop ?
I'd say the Chuwi Hi13... It's display is 3000 x 2000 pixels and can use the pressure sensitive stylus to draw and do graphics editing.
1982-1994
8 inches ideal size but battery a bit too low.
Posted with 2014811 via PCWX
xiaomi mi pad 3. battery at least 6000mAh.
can get it on qoo10 at around $350 SGD.
edited: forgot it is only WiFi ,not a GSM device.
Sony xperia z3 tablet is good enough. 4500mAh. that's if you do not mind a 2014 tablet.
otherwise, sharp sh06f 7inch with 4200mAh, with IGZO screen. but not easy to get in Singapore. if not, order from japan.
SuperDecker
hi everyone, looking to get a cheap tablet for light/moderate gaming and looking at the ifive mini 4s. its out of stock at banggood (on 20% stock clearance), other than aliexpress, any other reliable place to buy? i saw some negative reviews on gearbest.
Computeron
my hibook pro suddenly cannot boot up... dont tell me uplorry.
plug in cable also no charging light.
fat_boyz
Battery problems are common for chuwi tablets. thats why should avoid
not only battery, but the power adapter and USB charging socket on the tablet... use less than 4 weeks the type-c usb tip for my Hi13 broke in the charging socket and the charger kaboom...
Teo Ming Ern
That's why I swore off using China tablets... I spent quite a bit of money buying a few of these tablets and they all had issues with battery life, electrical leakage while charging, software faults, touch screen problems, and a myriad other issues... adding all that money up would have gotten me an excellent brand name tablet from Samsung or Sony or even Apple... just too much trouble...
produde1999
Huawei or xiaomi will do fine
yusoffb01
the leakage while charging is because you use 2 pin charger. 3 pin works fine
