Mobile safari ads spyware
jq75
Surfing hwz forum and accidentally click on something on site ad and leads to ads.
How can I clean it up?
renfred89
HWZ got spyware meh.... these are ads stored as cookies. Just need to delete them away by clearing cache and cookies will do..
jq75
y aren't u using an adblocker?
It's turned on in settings, but as I scroll the page, could have tap on some nonsense and it prompt me 'win iphone' malware pop up screen
chris888222
Ads aren’t spyware.
But yeah, you should probably install an adblocker. Plenty of options from the App Store but personally I use adguard.
Edit:
Usually I force close safari and then quickly remove the ad tab when I encounter the “winner” stuff.
jq75
Ads aren’t spyware.
Edit:
How do u remove the ad tab?
jq75
I've cleared all my safari data, but at random times on hwz forum page, it'll still change to an ad or 'scam' message which I can't go back
szeli
use a better adblocker
jq75
bosssaizo
Senior Moderator
Senior Moderator
hmm if can provide the URL will be great so that boss can block them :s12:
szeli
any recommendations?
I'm using Adguard which has user configurable rules. there r so many others like BlockBear, Purify etc. just search for content blocker in e App Store...
jq75
prefer to seek recommendations for a simple to use and yet effective one.
only worry is that it'll slow the phone.
not aware tt idevice also need such 3rd party blockers
szeli
just go try n figure out for yrself? all those mentioned work plug n play. Adguard has additional features...
not aware? umm all browsers work like that dude :s22:
