the OnePlus 5 !!!
peterc
Sticker abt NFC? Nope, did you see the red circle that I drew? I believe it is a very deep chip on the camera glass... am I right?
my set has it too. not to worry. might be a "design" thingy to differentiate with the fruit phone =:p
Alexz_Hong
So is it normal? does your OP5 has that deep chip too? I just want to confirm this.
Thanks.
it's normal. It's just the way they designed the NFC antenna since NFC probably doesn't pass through metal well. It's not a very elegant solution, but works. :s13:
6056399192701287710%253Faccount_id%253D1
bvoice
Just collected my set from 131 Express. Staff was friendly and patient enough to allow me to check through the phone.
Now waiting for my Nikin case and glass protector from Taobao! :s13: Btw, the phone doesn't come with an earpiece?
doki81
no earpiece...nowaday...customer very picky....give already..later sound no good..will hiam ..might as well don't give. :s13:
Myu~sun
Thanks.
My set has it too . Initially upon receiving it the first thing I notice is why so suay got chip . Then I go online see see look look . Then turn out to be design
tigabert
Just to check with you guys..When you type *#*#4636#*#* and go into phone information, under "Set preferred network type:" is it default at "TD-SCDMA/CDMA/UMTS"? Can't seem to change it to any other options as it goes back to default everytime
Clasde
Hi guys, will there be any difference when third party usb c wire of 2A or 3A are used for charging oneplus (mostly through portable charger)? Like damaging to battery etc.
shichuanhua
Portable charger no difference as long as cable is specs compliance
doki81
yes, that's the default value.
make sure buy good quality usb c cable. at least those well known brand.
also, if you use 3rd party cable..you can't activate dash charge with the default adapter...
Clasde
I'm probably buying from qoo so Baseus or REMAX should be fine right?
osmond19
Or just to be having correct equipment, supported network and location vicinity. ;)
Very strange. My mum Zenfone 3 with M1 able to get 4G+ at home but my OP5 beside the Zenfone 3 only get 4G instead of 4G+. Wondering what make Zenfone 3 so strange. Doing speedtest, Zenfone 3 with 4G+ get abt 90Mbps download while OP5 only 40+Mbps.
jackycar
OP5 don't have bands for 4g+ in SG, but other countries got.
But do u know when u EVER use 40mbps? Data allowance so little 40mbps and 90mbps u won't feel a diff one.
Main importance on lte/4g is latency and ping, as long as it's good u won't feel a diff
deathst
What.. It totally does..Unless this thing is lying to me
Dual Band 4g (M1 & Starhub)- 1800 & 2600 Mhz
Tri-Band 4g (Singtel) - 900, 1800 & 2600 Mhz
OP5 has these bands
Code:
4G (LTE)
FDD LTE: Band 1/2/3/4/5/7/8/12/17/18/19/20/25/26/28/29/30/66
TDD LTE: Band 38/39/40/41
3G (UMTS/CDMA2000/TD-SCDMA)
UMTS(WCDMA): Band 1/2/4/5/8
CDMA EVDO: BC0 (800)
TD-SCDMA: Band 34/39
Plus all our telcos have 4G aggregations M1 and SH using 2 band and Singtel using 3 bands
