Hi peeps.. I was quoted 4.6k for mitsubishi system 4 by gain city.
MXY4A28VA x 1
MSYGE10VA x 3
MSYGE26VA x 1
All with upgraded materials,stainless steel bracket, 2 trips and extended warranty 5 years with disposal of old aircon. Is the price ok?
MXY4A28VA x 1
MSYGE10VA x 3
MSYGE26VA x 1
your A28VA confirm not powerful enough even if you on 3 10VA in the bedroom
this is my quote from tim wong for my 4rm bto
4A38VA x 1
GE10VA x 3
GE18VA x 1
ARMAFLEX class "o" half inch, keystone control cable
2 trip installation.
5yrs warranty on compressor
gaincity give you what brand of insulator?
Reasonable quote.
My usage will only be one bedroom and living room. The other 2 bedroom as guest rooms. Insulator given is armaflex.
MXY4A28VA x 1
MSYGE10VA x 3
MSYGE26VA x 1
All the products are now made in Thailand. Cannot be one model in Japan and another model in Korea and another in Thailand. So long there is QC quality control, no worries. Think of mobile phones made in China for Samsung, Apple - are they anyhow made?Why so expensive?
Mine one MXY4A38VA compressor and system 4 at most $5100/- installs a yr ago. All materials upgrade some more.
Buy 38VA better, cos it's the only model made and assembled in Japan. Other ME model assembly in Thai I think.
Why so expensive?
As above... looking into air conditioning 3 bedrooms and the living room.. my contractor quoted me $3.7k for a 4:1(2 compressors inside) toshiba system with inverter.
is it expensive?
any lobang/recommendations?
is daikin or mitsubishi better?
Curious to check with bro's here. I came across Q10 selling a DIY Aircon cleaner under the brand name Jackie... did some search on hardwarezone and see that got some reviews. sorry to hijack but anyone got use before? any opinions?
Thanks
Hi guys, i just got my new aircon replaced yesterday.
Mitsubishi system 3 (2 ticks) at $3500. It's super quiet as compared to my previous Daikin model. Cools up within 5 mins at 25 degree, probably new ba.
My first time handling this, zero knowledge of AC. I have a few questions here :
1. The aircon ppl didnt replace my PVC cover leh, they just re-use it. Open, change gas pipe and seal back.
2. They didn't change my water pipes. They only change my gas pipes cos previously leaking bad.
By right is like this?
