tigerwoods
- Oct 7, 2005
This shop reliable or not, selling faulty set.
happens to me wen I try to unlock the phone while charging.starting to wonder if my G6 fingerprint reader is occasionally defective, I have incidents of 100% failure to read fingerprint in all unlock attempts, until the attempts are all used up.
What happens is that the phone will do its vibration motion, presumably detecting that there is a finger in contact, but it fails to authenticate, and prompts try again
problem is not solved when using different registered finger, or when phone is reboot, or when finger and reader are wiped clean just to be sure
being such an intermittent issue, it becomes something that is near impossible to demo, even if i go service centre. currently it is my #2 pet peeve with my device, with the #1 pet peeve being that god awful post processing oversharpening for camera
does local set has Quad DAC and Wireless Charging?
Collected my G6 today, just want to check whether the phone come with a screen protector installed already? saw a black film on phone but without tab.
Looks like a screen protector, but can be easily removed after a few days usageCollected my G6 today, just want to check whether the phone come with a screen protector installed already? saw a black film on phone but without tab.
Upgrade from g3 to g6, so far so goodI have been using LG G4 and hesitating if I should upgrade to LG G6 or Xiaomi Note 5 which is cheaper. LG G4 got a couple of problems. I encountered the boot-loop problem which forced me to go back to LG service centre. Today, my battery gets heated up quite frequently.
Does LG G6 have the same problems with LG G4?
the extra 12mth warranty needs to register anything to get it?
Was told to keep the receipt by red white mobile.
I changed from G4 to G6 which I'm using now. Very happy with the G6 and everything is better. I do miss the removable battery and 2nd battery which I could change on the go but at least the G6 has better battery life and charges faster. I'm quite a gamer and run many games but the G6 does not heat up at all unlike the G4. The only things I missed on the G4 is the better front camera and speaker sounds a bit better. Other than that, G6 is a huge upgrade
Keep and register warranty online.the extra 12mth warranty needs to register anything to get it?
