Is a 128GB iPhone an overkill?
Scooby-Doo
Description of myself.
Generally no gaming apps, just apps for chatting (LINE, telegram, whatsapp, FB Messenger)
Few social apps (FB, IG_
Intend to put songs into iPhone, non-English songs as English songs can use Spotify...
Is getting a 128GB iPhone for myself overkill?
icyflame
Yes, if you dont take and store lots of photos.
Even if you do have lots of photos, maybe cheaper to get less storage but sign up for iCloud.
Arandalo
if take 4k video very fast use up
else if your whatsapp group chat always a lot of photo or video also quite fast to consume storage
duhduhduh
Because of my laziness to do housekeeping of photos, my 64gb gets filled within 1.5 years
*adiBOY
Usually storage only increases when you upgrade the phone. It’s only going to get bigger. Even if Apple were to offer you 1TB of cloud storage for free, you’ll still go for a higher storage.
Scooby-Doo
thing is
I aiming for SE 128GB but also thinking of 7 32GB. People have been saying I am shortsighted for choosing SE as it is generations behind
Scooby-Doo
So 128GB SE the way to go?
tec_geek
Do you guys pay for iCloud to back up all those GBs?
Yeap, I did. I used to sign up for 50GB but later upgraded to 200GB due to large iCloud Photo Library dated from 2011 (after clean-ups occasionally), several backed up devices to iCloud and storing documents in iCloud.
But in iOS 11, I have upgraded to the 2TB subscription to share within the family as Family Sharing. Thus, instead of each having 50GB-200GB, cheaper to share the same amount of storage space, as some uses more and some using lesser data than others.
The 200GB or even 50GB should be sufficient enough. Am using iCloud as when I’m overseas (or in SG), it can automatically backup and if there’s any issues with the iPhone, I can pop in to any Apple Stores and need be to replace the iPhone, I can restore the data immediately without the need of iTunes or going back to get a computer.
icyflame
Same here. But only I am on ios 11 so cannot share for the time being
tec_geek
blues7
That's convenient
Yet to use iCloud for backup
Mainly becoz of small capacity that comes 'free'
Been thinking of subscribing for more storage
Will be good becoz it forces users to organizer the stay sorted more frequently
mun
new series of iphones don't have 128gb, which makes 128gb just nice and 64gb too little with 256gb as overkill :p
