HWZ AMD Ryzen R5 Owners Klub
royfrosty
Still rocking on my 2400mhz rgb trident z. Oc till 3066mhz 16 18 18 36 1.35v.
MacClipper
The chipset of RAM sticks seems more important than the model of the sticks, G.skill has been shown to use the same exact underlying PCB under various models.
From your info, those are probably Hynix sticks too.
royfrosty
Yeap they are Hynix. There are new models coming out soon. Only the 3200mhz and above ram kits with cl14 timing. From the looks of it it should be sammy b die.
TsQ
For 50% surf net , 30% office work, 20% non hardcore gaming... will Ryzen 1700 waste money and just stick with 1600 ? I won't overclock.
bernier
Hi, till how far can oc ryzen 3 1200 + msi b350 tomahawk + gskill ripjaw v 2400 2x8gb? :o :s12:
singupingu
bernier
Wrong thread lar lol
Here is Ryzen 5 leh.
With stock Wraith Stealth, don't expect too much. 3.6 should be achievable. Ram wise, stick to XMP profile. 2400mhz. Any higher have to experiment your own ram timing and dram+soc voltage.
Noted on XMP + 2400mhz. I have Cryorig M9a can still push some more? :o :s12:
Ripjaws v 2400 was able to run @ 2800 @ 14 14 14 1t on b350 strix b4. Should be able to have same mileage if not better on tomahawk which i feel slighty friendlier.
https://forum.lowyat.net/index.php?act=Attach&type=post&id=9084146
Also depends on ur luck with sillicon lottery
We have encountered an R5 1600 that can go to 4.0Ghz easily at 1.35V on Tomahawk. Another R5 1600 we had crashed at anything beyond 3.75Ghz also on Tomahawk
Both on stock Wraith Spire cooler
ah_khoo
Agreed on d cpu mileage part sir. Have yet to try 6c chips but out of 1x r3 (1200), 2x r5 (1400 n 1500x) n 1x r7 (1700) none can do 4ghz easily. Benchable yes, on d 1200p n 1700 but nowhere near stable for 24/7 (my standard is p95 stable).
For Ryzen oc i personally think apart from cpu cooling vrm plays a very important role. Budget boards (b350) arent really meant for r7 imo, vrm can get prerty toasty due to no of phase on b350 boards. X370 is safer bet. Some more, memory mileage afe better too on d x370 boards.
Guyver
Today just joined Ryzen R7 Club .. too bad dont have this club in hwz . havent install the hardware yet .
jtjt00
Welcome to Ryzen family, does not matter if R7 or R3 used in rig.
MGeaR356
Guys looking to upgrade to Ryzen 5 or 7.. Can recommend a best bang for buck in terms of
Overclock
Gaming
No need sli cross fire
Ram best can hit 3200mhZ
No need rgb
Motherboard and ram?
royfrosty
Overclock
Gaming
No need rgb
1600
Asus b350m-a or another value tier msi x370 gaming plus motherboard, but of cause if you want value then the asus b350m-a
Ram can just get gskill trident Z rgb 3200mhz kit, the ones in sls selling non rgb ones arent that great imho.
singupingu
MGeaR356
1600
thanks bro.. what about the hsf?
to get these from q10, amazon or tradepac (assuming still cheapest)?
also if prefer a x370 mobo by gigabyte or asus or asrock mobo.. out of the 3, which one has the best bios update rate? msi gfx gave me bad experience.. so dont really like msi
ah_khoo
If ur lookin at r7 i'd strongly suggest x370. B350 vrm is kinda limited to take d beating from 8c16t chips. Else msi tomahawk is decent for 3200 depends on ram.
