[Mini ITX] First time building help!
shengheee
Research a bit on it.
AMD on par with Intel liao.
Better worth in terms of value. But if can wait, wait for Intel 8th Gen on October and judge again. As of now, I would recommend AMD as it is a better buy as of now during the time I post this.
I wait for the 8th Gen intel to come out ba. My current laptop still can dong.
Zhun ah, ram 2133 MHz also can ah. That casing like nice leh. I saw one also, Thermaltake core V1.
Zhun, you can check youtube for test being done, not noticeable performance boost.
Core 500, I personally using, have the best air flow to me. Core V1 the rear fan are using 80mm eh, noisy and doesnt move much air besides the fact 80mm are hard to find alr.
My Core 500 I send to some handyman to cut away the vents on the top and side, fresh
unobstructed air intake!
shengheee
Nice. But my house a bit dusty leh. I worry the accumulation of dust on the case.
singupingu
shengheee
shengheee
Case exterior/ dust filter vacumn cleaner
Interior components ONLY canned compressed air / compressor
Any reason why internal components ONLY can be cleaned by using canned compressed air/compressor??
Also, where did you get your Fractal Design Nano S? I think i'm purchasing that first before purchasing the other stuffs.
Built the core V1 a couple of times with 2x Arctic F8 80mm fans at the back, which seem to move the air quite a bit on the contrary, pulling the hot air away directly as it is just beside the CPU HSF and GPU.
Temps look great for my cases. So not sure what fan you used that you say the air don't move much.
Sent from PM me if you wanna build a DIY PC or wanna learn how to make one yourself :D using GAGT
80mm fan move less air than a 140mm, that's a given, so why go with 2 fans when u can go with just one 140mm. Less cable, less noise, more air flow.
joshuaho
U don't want to risk shorting the board by rubbing the brushes of the vacumn cleaner over it..
Bought it from make fine SLS as they were the only one having stock at my time of purchase haha. U may want to check out the newer silverstone RVZ03 << iirc that's the model number.. has quite a nice design
singupingu
Just justifying the Core V1 doesn't have airflow issue. I know 140mm move more air but also considering the case is larger in size too. Cable management is fun imo, noise level is controlled by your fan curve. So those are minor issue only to me.
singupingu
Fractal Design Node 202 $129
Fractal Design Define Nano S $119
Silverstone RVZ03 RGB $169
Thermaltake Core V1 $79
Prices all in SRP. See which design you like and which suits your budget.
Huh? Larger? V1 is taller, Core 500 is longer only but shorter.
Ya fun, but why have more wire when you can have less but achieve the same or more, more efficient system design that way mah.
Besides, most itx boards have like 1 fan header only, cant control all fans. So why limit the air flow to reduce noise when you can max the air flow with lower noise.
singupingu
They are mostly available at SLS right? I maybe dropping down to take a look.
Yeah mostly available.
Alright you got your points across. Core V1 is indeed inferior compared to Core 500 but I still insist on the point there's no airflow issue with the case.
Dont get Nano S, your gpu fan intake will be block by the psu, affecting gpu's thermal by quite a bit.
Fractal Design Core 500 $99
Use SFX PSU to relief the problem. Or just like what you suggested, Core 500 works too.
