iOS 11 Update Guide/Discussions
Sephir0th
Been on this since the 1am release time. Like everyone said, lag has disappeared after indexing and caching.
Batt life definitely worse now. I feel it has to do with the auto brightness feature. 10.3.3’s definitely better when it comes to this.
On iOS 11, my screen is either too dark or too bright and I have to adjust it constantly.
VodkaPear
Just realized after the update. My iphone doesnt really sync well with photo icloud.
Only my ipad sync correctly.
How to resolve this problem ar? On/off icloud photo doesnt help.
tec_geek
I have encountered this issue before when I updated to iOS 11 during the betas.
Might wanna sign out from iCloud and then signing in back?
Otherwise, you might wanna delete some of the recently taken photos that aren’t synced as they may be deemed as ‘corrupted’. You may of course export those images out first.
If that still doesn’t work, I did turn off iCloud Photo Library, sign out from iCloud, and delete all the images from the photo library.
(You may wanna backup the photos just in case if it really do get deleted, forever)
Then sign in to iCloud, enable for iCloud Photo Library and might take a while before the sync feature do get started up.
If all fails, backup your device and restore it.
VodkaPear
Thanks. I will try later. Hopefully it works.
As I am very lazy to restore the phone, since iPhone X is coming soon.
swgj86
the auto brightness feature can be disabled.
PumpkinX
I find the animation when opening safari seems to be lagging. Closing is fine. iPhone 7 Plus
kmkimlo
Have you all tried resting your thumb on touch id after the phone is unlocked?
Mine will keep activate the button even if my thumb is just resting on it and no pressure applied.
metamofia89
Turned on auto brightness and set my brightness level at a lower level. But seems like my screen is still quite bright and sharp in normal room lighting.
Could it mean the auto brightness isn’t working because the display accommodations is toggled off when the auto brightness in it is toggled on?
blues7
iOS11 has new settings for safari?
Most websites on safari now cannot load pictures
Used to be all pictures load quickly
But now, safari got ‘auto protect’?
If click on picture, safari say not safe
And give option to ‘go back’ or proceed to view picture
Very inconvenient
Anyway we can remove this ‘auto protect’ feature on safari?
szeli
Very inconvenient
any examples? not sure if it's related to e new prevent cross site tracking option...
metamofia89
Home screen froze again. It’s getting annoying because I’m actually testing out my battery life. Hope this gets fixed this week.
arcturuz
2nd day, my ip7 battery life still v poor
hopefully will be better by tomorrow
Thoma5
Give its a few more days as most ppl said down here. My battery life start to get better...
ooolong
No leh, IP7+ here.
metamofia89
Anyone considering to downgrade to 10.3.3? The freezing of the home screen at random is quite scary.
