shichuanhua
- Mar 2, 2012
u mean at the video listing there and scroll?
yup , that one should be more visible
Isn't jelly screen supposed to be in every oneplus 5? Or some have some dosent?
Anyone experience any problem with singtel? For some reason internet loading slow, grab Uber time etc.. WhatsApp send messages etc have a buffer time ...
Anyone know? Why suddenly will drop to H+?? Like understable
so oneplus is sending all our data to the mothership, anyone got solutions to stop the tracking? so far i follow xda instructions and uninstall an app via adb only but probably to be safe should flash a clean custom rom...
cos the signal week? mine is sometimes 4g+ to 4g... but it's better than last time which only 4g available..no +..![]()
Jin happy
After update
4g+ at home
To update to 4.5.1.1, just download Opera VPN (free app) from App store.
Connect VPN, then set region to Canada.
Once connected go system settings check for update, 4.5.1.1 will show up
Super simple and safe method. Can't screw anything up
i think it's just some minor analytical data...as long as the data didn't involve any login credential or credit card info..i am ok to let them take....
Look at the former Carrier IQ mess a few years back. At first it was just some analytics, but the software was recording actual keystrokes too.
Thanks man. You are right, very seamless.
HahaWhat should be the speed test speed for 4G plus?
Oxygen OS 4.5.13 is available![]()
We are pushing out the incremental roll-out of OxygenOS 4.5.13 OTA for the OnePlus 5. Here are some of the highlights of this build:
System
Supports customization of notification ringtone
Improved launching speed of apps
Optimized adaptive brightness
Fixed issue of YouTube video lagging behind audio
Fixed display issues of some UI elements
Fixed issue of no 4G+ network in some regions
Updated Android security patch to September
General bug fixes
For those who were on previous versions for OnePlus 5, we appreciate your active feedback and attempts to reach out to us. With your help, we have been able to better optimize and improve several key areas. Thank you for your patience and as always, we look forward to hearing yourcontinued feedback in the bug reporting forum here: https://forums.oneplus.net/feedback/.
As always, this OTA will be incremental. The OTA will reach a small percentage of users today, and we'll begin a broader rollout in a few days.
Your feedback is appreciated. We may not always be able to respond to every comment in the forums, but please be assured that we take your comments and feedback seriously. Hope you enjoy!
I was having problems with WiFi as well. Sometimes it just stops working even though WiFi still shows as being connected. I have to reboot to solve the problem. I just updated to 4.5.13. I hope this update fixes the problem.4.5.13 help the wifi instant connect for me can start surfing previously on 4.5.11 & 4.5.12 I need to wait maybe 10 seconds. Some apps like oneplus community I can't use wifi it won't work, now it's back to normal for those apps.
