[Software Update] iOS 11.0.3 Discussions
MeetYourTea
Battery life for 11.0.2
Will do a 11.0.3 soon.
Mach3.2
encountered some unresponsiveness when i tried waking my 7+ using the home button.
there's haptic feedback but the phone takes a few extra second to light up the screen and unlock the phone
metamofia89
It seems like the battery draining issue is present on my 7 on iOS 11.0.3. Not by much with 85% after 70 mins of using the phone. Usually get 91% - 92% with the same usage pattern.
KeYoKe
Hmmm, it seemed like ios11.0.3, when u off wifi at the quick toggle, it off wifi now instead of disconnect wifi only
renfred89
Wierd why mine will off :s22: which iphone generation u all using?
I can conclude it doesn't turn off but merely just disconnected.
Tried on iPad 10.5 2017 and even iPhones of various generation as well.
in 11.0.3, control centre will now says "disconnected [wifi name]" or bluetooth when you tap it, but it doesn't have a stroke across it.
ForumRider
my 6s plus also same thing, i disconnect the wifi n bluetooth from control center. Went to settings and found both were off .
KeYoKe
Hahahaha ya. I also dont know leh... Thats why thought its fixed. I tested out 5 times liao even rebooted my phone, when i off the wifi, it turns off the wifi instead of disconnecting. Previously it disconnects like what everyone mentioned here :s13: i hope this bug stays here hahaha
Odessa
Obviously a bug because Control Centre is only meant to disconnect, not disable - http://bit.ly/2wWld3k
Verified on my own iPhone 6S Plus
