Xiaomi Redmi 4
itsme220
I bought Redmi 4 from overseas on sale
This has network spec
GSM B3 (1800MHz), B8 (900MHz)
WCDMA 900 / 2100MHz
FDD LTE B1 / B3 / B5
TD-LTE B40 / B41
Will it work with 3G (M1 network) and M1 4G?
Thanks
csc12345678
I think I've mixed up Redmi Note 4X and Redmi 4X.
I need to get a case and screen protector for my Redmi 4X. Do I have the concern of the China/Singapore version case/SP incompatibility ?
I'm confused already. I try to trace the forum but there are a number of entries and I'm not sure. Thanks for your help. Thank you very much.
To clarify, my question is if I order online a Redmi 4X screen protector and a case, would it not fit the phone I purchase in Singapore. I read before that there were some mixed up between China and Singapore Redmi 4 and 4X and the accessories would not fit. But I cannot remember if it was referring to Redmi 4X or Redmi Note 4X.
ZrE0_Cha0s
if u choose 4x definitely wont be an issues. and singapore only have 4A/4X other '4' variants not avaliable in SG, (in terms of our market other '4' variant are export set.)
csc12345678
Any concerns for updating to 8.5.2.0 ? Should I update ? Having a Redmi 4X. Thank you very much.
ZrE0_Cha0s
well u can check on MIUI forum for more info on this as my redmi 4 prime didnt receive such updates atm.
edit im on 8.5.4.0 so i think even with your 4x on 8.5.2.0 shouldnt have any issues. (base on my current updated software for a quite 4~6mths, cant rmb when i updated)
ZrE0_Cha0s
New update V.9.5.4.0 NAMMIFA available. Read it causes battery drain. Anyone updated on the Redmi 4X? Feedback ? Thanks very much.
Even my 4 prime also have this notification, but dun dare to install due to numerous report on the battery issues(beside drain, some can't even charged :s22:)
csc12345678
updated already ? How ?
There is a feature in this update that allows you to watch Youtube in split screen, right ?
ZrE0_Cha0s
I read somewhere for this update (not on R4X though), can just disable MIUI optimisation and memory optimisation, battery ok.
Wah my r4p updata now only able to update to 9.2 instead of 9.5. Would said that thank god i didnt do the update. But i have of yet checked whats the isssues.
iammole
V9.5.5 is Miui 10?
I'm still on the original firmware. Any significant changes? Can do split screen?
ZrE0_Cha0s
Yup. I updated my 4 prime to miui 10
for prime i have of yet received it. but i checked the miui forum, they have indicated that only randomly selected userr have it. and btw can u check if it on android nougat or still that 6.0?
