[Software Update] iOS 11.0.3 Discussions
chenaz
It say disconnect instead of “off” anyway I am on 11.02 not 03 so I donnoe how 03 works
Mine also off. Same like u. Iphone7+
renfred89
as long as the toggles in control centre doesn't have a "\" symbol across the toggle, it means its still active but merely disconnected.
Lucky177
Previously while me on 11.02 is disconnect iirc. 11.03 when I go see settings, is off. Not just disconnect.
Btw, in either versions, I don’t have the msg as shown in ur ss.
I’m about to ditch iphone soon. At least temporarily... maybe when is stable again, I’ll rejoin the camp.
WhatsApp missing notification is a killer for me.
tec_geek
In all versions of iOS 11, it should function when tapped on the Wi-Fi toggle, is merely disconnect from the current Wi-Fi (becomes grey) or another tap to enable Wi-Fi to search for networks to connect (becomes blue).
Haven’t seen it being able to turn off from the Control Centre but only via the Settings option.
Lucky177
Ya. Supposed to be like that. But mine is off for this version, just like the other forumer posted previously.
Anyway weird.
chenaz
Yea I tot it suppose to work this way.
But some ppl below say their sis off when they tap on it.
I was envy that they are able to off it instead of disconnect haha
kmkimlo
Using IP 7 plus.. when I click, the WiFi is only disconnected not offed
szeli
have u tried leaving e app in e background or reinstalling? my WhatsApp is fine...
Odessa
I've also confirmed this with my friend's 7 Plus. Any existing WiFi and Bluetooth pairings are disconnected; these functions are not disabled.
Lucky177
Is running in the background. Missing notifications on n off happens. Is not totally no have. I don’t have such issues before this version even tho’ some mentioned missing notifications in screenlock that time. :s22:
Anyway dunno. Some complain about unable to unlock phone when was in landscape etc. Mine ok. No such issue.
Apparently many weird issues that only some experienced while some does not. Is good if those never experienced weird issues or bugs.
To a certain extent, I’ve enough of it. On n off also experienced white screen, text missing.... haiz. :s22: :(
Pherenike
I have the 6S but haven't update to iOS 11 yet.. scared laggy and too many bugs :s22:
ragnarok95
Senior Moderator
Senior Moderator
Actually after the WhatsApp update and on iOS 11.0.3... my WhatsApp notification is totally fine and normal. Lock screen appear, when gaming it also appear... works fine for me lol.
Matrock5
This iOS 11 and updates are really affecting older phones batt life. Charge to 100% use n surf Facebook reply emails within 30 mins it drop to 90%!!
Lucky177
Good. Mine was reverse. Ok in previous versions. Only Kee Siao in this version. :s13:
