Tried the demo unit for WF-1000x @Stereo Vivo city.. Felt that the volume of the earbud is too soft.. For those who bought it, don't you feel the same thing too?
I think it’s ok. I tried with iPhone 7 Plus. What device did you test with
I used it on a 3 years years old phone, OnePlus One tho.. Tuned to the max volume still getting equivalent to half of the volume of the wired Sennheiser Momentum In-Ear (Wired)
Actually noise cancellation don't really work as good as many reviewers said.
There are sound which cannot be simply blocked out and there are sound that will actually amplify and sounds louder than usual for example door banging sound.
Technically, it appears to sound louder because all other sounds have been removed leaving only those that cannot be removed. Imagine you are at a cafe, it's very noisy, people talking, cutlery sounds, traffic noises, etc. Then with ANC, no talking noise, no traffic noise. BUT, you only hear cutlery sounds. So it gives you the impression that they are louder than before.
Anyone can recommend a wireless sporrs headphone that is
1. Budget
2. Sweatproof and waterproof
3. Decent wireless range
4. Good battery life
Open to all brands including those from China.
Thanks in advance!!
Yes, for some reason android phones usually have softer volume than iphones.
I have a Samsung S8+ and find the Bluetooth volume really low.
1. Budget
Thanks in advance!!
bose just announced the soundsport earbuds.
damn swee, 5hrs batt life.
