I took a walk around Sim Lim and noticed the same cat cable with same length are selling at different price. How do I go about finding a quality cable with the best connection?
No way you can tell unless one dwells into the electrical properties of the cable which no layman will do. Even if u find out the cable is poor quality what can u do?
The rule of thumb is to buy from reputable retailers so that the cables they sell are usually okay. Their procurement department does alot of background checks and product testing before importing in bulk..
Buying from Sim Lim is it a risk? Or should I buy from challenger?
Cat. 5 can do gigabitChallenger is good and fine, as i had bought a 20 meters Cat 5e years ago, no problem.
Sim Lim Square accessories shop at 4th level (#04-70) where i bought Cat 6 & Cat 7 flat cables from them.
So far no problem.
Cat 6 and Cat 7 has no differences.
Cat 5e is fine as it is also for gigabyte.
Cat 5 is up to 100 Mbps only.
If you are getting 2 or more then consider different colours to easy differentiate.
WrongCat 6 and Cat 7 has no differences.
The picture you embedded agrees that Cat. 5 does 1Gbps.![]()
Cat5 Ethernet, introduced 10/100 Mbps Ethernet, also known as Fast Ethernet.
Source : https://planetechusa.com/blog/ether...t3-vs-cat5e-vs-cat6-vs-cat6a-vs-cat7-vs-cat8/
Nay, the picture not mine. Can't correct it.
That's why use word to tell Cat5 is only 10/100mbps.
Which is spell out in the article.
