Recommendation: Reliable workshops in JB
FinchGuy
Anyone can recommend workshop that can replace Nissan clock spring cable (the one in steering wheel)? My airbag light blinking. Thanks.
snipfer
Sent from Xiaomi MI MAX 2 using GAGT
Orangecolour
Hi! Just visited a ws and was charged Rm1330. Any bro can share their view on their charges?
Kumho 205/45/16 x2 Rm230 each
Power steering fluid - Rm45
Front left wheel bearing - Rm175
V/cover bush x5 Rm20 each
Rear wheel arm bush x2 Rm145 each
Alignment - Rm35
Power steering pump repair kit - Rm180
G/lever oil seal - Rm45
Was also quoted around rm200+ for rear caliper repair kit as the current one is leaking oil.
Thanks in advance!
yanbros
Alignment - Rm35
Thanks in advance!
Looks reasonable. In Singapore you change tire, 1 at least $100sgd. From there you can compare yourself. For what car?
Orangecolour
For Honda civic esi. The tyre is slightly cheaper than sg. Was quoted $85 each for sg. But the repair parts I'm not very sure! Hopefully didn't get carrot :s13:
yanbros
Wa... your car is indeed classic. Not many left in sg but jb easy to find parts.
yanbros
Oh god just saw another leak. Mech told me Is steering cover spoilt and because it's leaking means steering rack leaking oil. Anyone know the average place to repair these parts? :s22:
why don't you just return to your jb mechanic to repair? Since they already know the issue. Price seems reasonable too.
