November 2017 SBF
Ed.YEO
可以。。。單身者申請剩餘組屋沒問題。。。一樣兩房式嘍!
LiteHouse
its the same for all projects public or private, reason is that the people who bought at launch get a cheaper price because they have to wait longer. The longer the wait the cheaper it would be. Conversely, the closer to the date of completion, the shorter the wait, the cost would be higher. If the units don't get chosen during this SBF, it will likely be more expensive the next time round
But why unwanted units will increase price too?
Lexyyy
Pay premium for unwanted units yet subscription rates remain high! 70%......
parkson
Pretty sure they are not "unwanted", those units are there cause people last min change their minds, break up etc. Look at the mature estates numbers, they are always oversubscribed by quite a bit. People are willing to pay more if you can get your house in 1 year compared to 3-4 years.
tivo88
Buy SOBF got many surprises cuz u duno what you are getting.
Only buy if u need a flat urgently or if u can't wait for abnormal BTO to be built.
Usually cater to those people who got married or have children and desperately looking for a place which dun mind noise, low floor, near mcp, above bin chute, fengshui rejects or sun units
For many it's a good deal cuz they are in a hurry. If still got time then apply BTO slowly choose loh
flea_pepper
If the application rate is more than 1.0 means more difficult to get a queue number right?
flea_pepper
Ya but there are much higher rates for other hot sites
Depends on your eligibility and luck
First timer u got priority
Sigh. Only 2nd day and I'm giving up.
They should give 1st timer 100% and 2nd timer onwards 0%.
flea_pepper
I got another question.
How come some 3 room flats ceiling 6k and 12k in the same estate?
What's the difference apart from the ceiling income?
khkh8488
It's harder but doesn't mean you couldn't get a number.. Even after you have gotten your que number you might not get the flat that you have shortlisted.. some flats have been on SBF list for few cycles already
duameatball
precisely. HDB's motive for SBF and ROBF is to get rid of unwanted or repossessed units. so why charge people more for it?
If they don't charge higher, people will take the first phase of BTO for granted. Why apply for BTO when sobf is the same? Other than getting better units, there's no other benefits. Hence the price difference as well.
